Author Topic: Le Mans UJ Carrier Bearing - SKF Part Number?  (Read 5897 times)
Offline stuv65
« on: January 27, 2015, 07:53:31 AM »
I have the Guzzi part number for the UJ carrier bearing for my Le Mans Mk 5, but does anyone have the SKF part number please?
ta
stuart
Offline sib
Re: Le Mans UJ Carrier Bearing - SKF Part Number?
« Reply #1 on: January 27, 2015, 09:37:32 AM »
Check out this table at Guzzitech GB:  http://guzzitek.org/tableaux_guides/Roulements_Spis_Toriques_MAJ18.pdf
It cross-references many Guzzi bearing part numbers with SKF numbers.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Online Perazzimx14
« Reply #2 on: January 27, 2015, 10:31:16 AM »
Pull the bearing and look on the race for the numbers. Give these numbers to your bearing retailer and tell them you want a SKF bearing to match. If the numbers are not legable measure the OD x ID and thickness and give theses numbers to you bearing retailer.
Numbers will be something like 6206RS (60mm x 30mm x 16mm).  6206 is common within most bearing manufacturers as the "RS",  It stands for "rubber seal"
While your swing arm is out also get the pivot bearing sizes and seal sizes. I can get you the 3 bearings and 2 seals for about $40 USD. Don t know what shipping would be though. Bearings are KOYO.
« Last Edit: January 27, 2015, 10:36:28 AM by Perazzimx14 »
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline Doug McLaren
« Reply #4 on: January 27, 2015, 03:08:11 PM »
Try these fellas Stuart, I've always had good service from them.
http://simplybearings.co.uk/shop/advanced_search_result.php?keywords=6206
2019 V85TT
1994 Ducati 900 Monster
1957 Lodola 175
« Reply #5 on: January 27, 2015, 04:50:35 PM »
Most bearing houses would carry what you need.  The number off the old bearing will work.
Offline stuv65
« Reply #6 on: January 28, 2015, 02:18:22 AM »
Thanks all for the useful comments.
I should have said, from the bearing I removed I could only read "GERMANY"  and "S**" but nothing else.
Thanks again - ta, stuart
« Reply #7 on: January 29, 2015, 12:36:52 AM »
Swedish company that made the bearings in Germany.
