Author Topic: 1100 Sport Front Wheel Bearings  (Read 4059 times)
Offline ailgev
« on: January 30, 2015, 05:28:14 PM »
Hi There,
I was wondering If Anyone Knows Which Side The Smaller Inner Diameter Bearing Goes On On The Front Wheel. Both Bearings Have The Same OD However One Has A Smaller ID.
I Dont Have My Front Axle With Me And Looked Up The Parts Manual But It Doesnt Seem Right.
Does The Bearing Spacer Actually Slide Through The Bearing With The Larger Inner Diameter?
Any Help Would Be Appreciated.
Paul
Re: 1100 Sport Front Wheel Bearings
« Reply #1 on: January 31, 2015, 01:25:53 AM »
I don't know, but I'll bump this.
Offline jknight611
  • Gentlemens cranks go fore and aft
« Reply #2 on: January 31, 2015, 05:50:51 AM »
Don't know either, I have a Sport 1100 and next week when I get home I will be happy to pull the front wheel and send you some pics
1995 Sport 1100
2007 GL1800
2006 Ural Tourist
2010 KLR650
2013 Stelvio
Offline Murray
« Reply #3 on: January 31, 2015, 06:11:19 AM »
Injected or carbed? On the carbed 1100 sport the axel goes in from the RHS then there is a thin piece of tube on the LHS that a spacer fits over the top of ,next to the fork leg that the axel threads into. While I haven't measured the ID of the bearings I'd say the larger diameter has the thin spacer. The spacer would have the same ID as the smaller of the two bearings.
Offline ailgev
« Reply #4 on: January 31, 2015, 12:55:21 PM »
Thanks Guys,
Hi Murray,
Thanks Heaps , That Makes Sense.
The Larger Id Bearing Does Slip Over The Spacer On The Left Hand Side.
The Parts Manual Has Got It Wrong.
Once Again, Thanks Guys. Appreciate Your Help
Paul
