Author Topic: Recognize this obscure Guzzi part ?  (Read 15176 times)
Offline Dimples
« on: January 31, 2015, 05:25:44 PM »
I'm looking for these if anyone has an extra. Left or Right.
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'04 V11 Le Mans Nero Corsa
'77 850 T3
Offline bigbikerrick
Re: Recognize this obscure Guzzi part ?
« Reply #1 on: January 31, 2015, 05:28:19 PM »
I give up, Dimples, What is it?  Rick.
« Reply #2 on: January 31, 2015, 05:31:33 PM »
the round part looks like the holder for the rubber kick stand bumper and some gas tank rubber bushings. I never seen the triangular part tho, it it from a small block?
« Reply #3 on: January 31, 2015, 07:54:06 PM »
A 3 pointed mirror head pivot flange with clusters?
Beats us.
« Reply #4 on: January 31, 2015, 08:31:16 PM »
It's a round tuit on a triangle widget.  Fits the right-hand drive SM models only.
« Reply #5 on: January 31, 2015, 08:58:13 PM »
Turn signal reflector?
Offline Dimples
« Reply #6 on: February 01, 2015, 07:46:00 AM »
Yes, it slides into the back of the euro turn signal lens. They are asymmetrical-- there is a left and right side version.
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'77 850 T3
« Reply #7 on: February 01, 2015, 11:18:03 AM »
Good luck with that.  ;D I'd say you are going to have to make it if you want one. I saw a pair of euro lenses for a Lario go for $140 IIRC last year..
Offline dera
« Reply #8 on: February 01, 2015, 11:47:19 AM »
Hi!
That mysterious part - for what motorcycle?
California Über Alles
« Reply #9 on: February 01, 2015, 01:06:49 PM »
For..
 :D
Offline dera
« Reply #10 on: February 01, 2015, 03:05:19 PM »
Yeah  ;-T
Offline Dimples
« Reply #11 on: February 02, 2015, 06:07:55 PM »
Hi!
First, my post was a quest to find one of these parts.
A sheet metal reflector that fits inside the plastic "Euro" turn signal lens (Le Mans 1000, Lario, etc.). The photos below show a complete turn signal with the reflector in place. I was hoping someone saved one from a long ago broken lens.
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'77 850 T3
« Reply #12 on: February 03, 2015, 07:51:31 AM »
I was serious when I said you'd have to make one. It would be easy enough, but would take all afternoon.
Offline Dimples
« Reply #13 on: February 03, 2015, 08:22:35 AM »
Chuck, I took you seriously!
I have most of what would be required. Maybe attempt to spin the domed reflector on the lathe. I've never done it, but thought to give it a try (or press it). But you're right about it taking a few hours of trial and error.
So I decided it was a good opportunity to participate on the forum with actual Guzzi content and photos.
D
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'77 850 T3
« Reply #14 on: February 03, 2015, 08:56:24 AM »
D
Alrighty, now!  ;D
Off the top of my head, I'd think that spinning the reflector would be tough. It needs to be polished, and spinning would probably do away with that. The reflector needs to be riveted to the triangular piece, so the first thing I'd try is to make up a radiused punch with a locating tit in the middle that is the rivet diameter. Make the blank to fit that with the right hole diameter. Once it is formed, you can use that hole for the rivet.
Polish the punch.. very important. Make the workpiece out of polished stainless, maybe .010" thick. I'd first try pushing it into hard rubber and see how that works. If an arbor press doesn't work, hitting it with a hammer might. You *may* have to make a die, too.. but I doubt it.
Good luck.. there may be a little experimenting involved, or you might get it right the first time.  ;D
Offline bobdar
« Reply #15 on: February 03, 2015, 09:33:23 AM »
You might buy one of these and cut two relectors from it:
http://www.kingmetals.com/Catalog/ItemContent.aspx?ItemNumber=275
They show 2", 3", 4" and 5" diameter spheres.
bob darcey
lakewood, colorado
'75 850T
'56 Matchless G80
« Reply #16 on: February 03, 2015, 09:55:02 AM »
Too big a radius, and they'd still have to be polished..somehow. Not to mention, they cost money..(Guzzi content)  ;D
Offline Greg Field
  • The Signs Foretell the Rise of a Guzzi Lama . . .
« Reply #17 on: February 03, 2015, 10:02:47 AM »
I might have one of those ratholed in the rafters of the gay-raj. It'll take me a couple of weeks to find it, though.
« Reply #18 on: February 03, 2015, 03:47:19 PM »
It looks like you could go to NAPA and find a freeze plug of those general dimensions.  Drill the center for a #4-4 rivet and polish or reflective paint it and you're good to go.
« Reply #19 on: February 03, 2015, 10:56:47 PM »
Try a bit of the shiny side of tinfoil and wedge it into the amber plastic and see how it works.  I bought some cheapo blinkers that had no reflective material inside, did what I said here and it's close enough to be seen for what it is outside.  ;D
