Author Topic: Posi-Lock Connectors  (Read 24600 times)
Re: Posi-Lock Connectors
« Reply #30 on: February 03, 2015, 01:29:32 PM »
This. I use wire nuts frequently for temporary repairs and lots of times it becomes a permanent repair. Twist it on, fill the hollow with RTV, presto, watertight connection.
Yeah -- about that -- I was being sarcastic.  IMO nothing says "there was nobody to hold my beer while I did this" like wire nuts and skotch-loks hanging off a smoking wire harness.
Chuck -- Got that FAAology book handy?  Does it say why ALL the wires in an airplane are the same color (white?)
« Reply #31 on: February 03, 2015, 04:44:23 PM »
They're color coded. White is a color..  ;D
Offline sign216
« Reply #32 on: February 03, 2015, 09:09:07 PM »
I ended up soldering the connections.  It was for points and condenser, behind a flywheel, so space was limited.  Not room for the posi-lock connectors.  Although with that cramped space my soldering wasn't pretty at all.
Fyi, I've used posi-tap connectors before, to tap into the bike's wire harness, and they are Great!  Really.
Will test out the posi-locks another time.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #33 on: February 03, 2015, 11:26:55 PM »
I found this interesting thread.  Notice the photos a page or so down:
http://www.apriliaforum.com/forums/showthread.php?195032-Posi-Lock-connectors
dilligaf
« Reply #34 on: February 04, 2015, 07:00:11 AM »
Jim, It looks like the connections were poorly done generating heat.  Over time corrosion can build up on any connector causing the same condition. As posted above Posi-Locks are not my first choose but the ones on my SP have been in use for many years a 30K + miles. In my opinion they are a PIA to make correctly.  :BEER:
Matt
