Author Topic: Pinched Tube Behavior - NGC - Harley  (Read 25303 times)
Offline Enrico Pallazzo
« on: February 03, 2015, 02:49:57 PM »
Wondering if people could give me some info on pinched inner tubes.
I got a screw in the rear tire on my Softail the other day. It leaked slowly, so I was able to pump it up and ride it to a shop. They put in a new tube. Then over the weekend, I rode to Key Largo and back. On the way back, about three miles from the house, I noticed the steering was wobbly. I pulled into a gas station, and sure enough, the tire was going down again. I managed to get home at 20 mph.
When I pumped the tire up to 40 psi, the air really flew out of it. I couldn't find a nail or screw. The air really rushed out, as if the leak got worse while I was limping home. Now I can't even make it out of the driveway.
I am thinking the tech pinched the new tube somehow while installing it. I am waiting for the shop to call back. But this got me wondering: is a really fast leak generally indicative of a pinched tube? Also, is it normal for this kind of leak to get worse while you ride?
My Jackal has tubes, too, so whatever I learn will apply to it.
People who claim they don't have ten seconds to answer your stupid questions can always find several minutes to criticize them.
Re: Pinched Tube Behavior - NGC - Harley
« Reply #1 on: February 03, 2015, 02:59:10 PM »
Don't know where you live but "... Key Largo and back" is far enough to give pause as to a pinched tube. Coulda ran over something for a puncture and the entry hole is scuffed over sufficiently as to hide it. Pinched tubes (my fault) usually have exhibited their presence almost immediately.
Todd.
« Reply #2 on: February 03, 2015, 03:01:06 PM »
It could be the tube snout wasn't properly installed and got abraded or cut.  This mystery will be solved when you pull the tube back out.
« Reply #3 on: February 03, 2015, 03:02:27 PM »
Key Largo is not far from here. The ride was a little over a hundred miles, total.
Offline redrider90
« Reply #4 on: February 03, 2015, 03:11:07 PM »
My dime is on they left something inside that is caught between the tube and the tire. Most like a very small item even a very small stone or even the washer that goes between the valve stem and the rim.
I did that very thing. The washer unbeknown to me slipped out of my fingers and landed between the tube and the tire. After 15 miles I lost all air fast. The vibrations wore a hole in the tube from the washer. What makes me think it is something smaller is that you got 100 miles before you lost air.  I think a pinched tube would have revealed itself sooner rather than later. But I suggest you be "bedside" when they pull the tube and have a good look see inside the tire.
Heck it may also be the rubber guard that protects the rim/spokes from the tube is out of place ever so slightly.
Red 90 Mille GT
« Reply #5 on: February 03, 2015, 03:14:41 PM »
They are going to cover it if it's their fault, but to find out, I have to bet them a $50 trailering fee. Not sure if they'll eat that or not.
It would be a hell of a coincidence to get rear-tire flats on two rides in a row, on different roads.
« Reply #6 on: February 03, 2015, 03:33:22 PM »
I rode along with a woman on some Honda a few years back.  She got three nails in her tires -- two front and one rear -- in one day's riding, some hundred miles apart, on the same road.  It was a bad day for everything except the slime compressor.  That little turd performed as advertised.  When we parted ways a couple days later I gave her my patch kit (but not the compressor).
« Reply #7 on: February 03, 2015, 03:58:08 PM »
RK may be right too, if the tube wasn't positioned well then it could also be the stem cut through.
On previous bike I pinched tubes all the time.  Showed up immediately.
If it isn't something picked up on the road I'd bet on something left in the tire.  A tech here let that little washer get between tube and tire on one of mine.  Went a few hundred miles before it wore through.  Slime and a compressor (also slime) got me home that time.
After that I converted my rims to tubeless  :D
« Reply #8 on: February 03, 2015, 04:21:25 PM »
I am not in love with the tubeless rims. I didn't know the Harley rims were made that way. Not a big surprise on the Jackal, for $7000, but the Harley cost a little more than that.
« Reply #9 on: February 03, 2015, 07:12:46 PM »
  Flat tires happen to all of us.  The only way to know what caused it is to take it apart.
LaMojo
« Reply #10 on: February 03, 2015, 08:06:02 PM »
Maybe that Chinese tube split at a seam.
LaMojo
« Reply #11 on: February 03, 2015, 08:07:40 PM »
Offline 1Sourdough
« Reply #12 on: February 03, 2015, 08:35:16 PM »
I had a flat one fine day, about half a mile from a garage.  Folks there pulled the tire and patched the tube.  Thirty some miles back to Elkader, and a little while after arriving the tire was visibly low.  Enthusiasts had the tube out and replaced in just a few minutes, and I left again.  Tire went flat a third time.  We arranged to trailer it home while I rode the Good Samaritan's Guzzi.  Wheel off the machine and to a local tire shop, where a tiny, perhaps 1/32nd or 3/64th inch grain of gravel was found inside the tire.  It doesn't have to be a big hole, doncha know!
1993 Strada 1000, 1996 R1100RT, 1999 V11 EV
                            -30-
Offline Petrus Rocks
« Reply #13 on: February 03, 2015, 10:19:12 PM »
Another thing to check is the valve core.  Sometimes the core isn't tightened completely and will slowly leak.  This could cause the slow leak you describe.
My experience has also been if you pinch the tube it deflates pretty quickly.  I have had to run my fingers carefully around the inside of a tire to find a puncture problem as well.
Offline SED
« Reply #14 on: February 03, 2015, 10:34:15 PM »
I'd bet the reason it's leaking faster now than on your ride is that the low tire pressure let the tube slide inside the tire and pull the valve stem partly out of the tube = fast leak.
Why the new tube went low during your ride is hard to know, but on my bicycles it's usually when the initial puncture is due to broken glass and a little shard remains in the casing.  It cuts through the tube after a few miles becoming a slow leak that gets faster with distance.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
« Reply #15 on: February 04, 2015, 09:52:58 AM »
The shop is sending a trailer today. They proposed the same solution I was going to: if they screwed up, they pay for everything, including picking up the bike. If not, I pay. Good enough for me.
« Reply #16 on: February 04, 2015, 10:30:21 AM »
Here's a question I should have asked: how do you prepare for tube-tire flats? I can't use plugs while I'm on the road, so what's the answer?
« Reply #17 on: February 04, 2015, 10:45:41 AM »
Sounds like I'm screwed. I mean, there is no way I can get the tire off a Harley on the side of a road, with no lift and no tools to speak of. Especially the back tire.
So there is nothing I can shoot in through the valve, like Fix-a-flat?
« Reply #18 on: February 04, 2015, 10:57:43 AM »
why not?  Tubeless + Patch kit would've saved lots of grief.
« Reply #19 on: February 04, 2015, 10:59:10 AM »
see above.
best answer is tubeless rims
« Reply #20 on: February 04, 2015, 11:00:05 AM »
Meant to say I was not in love with tubes.
Offline HDGoose
« Reply #21 on: February 05, 2015, 07:52:44 PM »
Cue Hagan....
« Reply #22 on: February 06, 2015, 05:53:36 PM »
The shop called. The tube failed at the base of the stem. They're paying!
« Reply #23 on: February 06, 2015, 05:55:59 PM »
Cool  ;-T
« Reply #24 on: February 06, 2015, 06:04:51 PM »
Yeah, that was a hundred bucks I didn't feel like paying twice.
Offline redrider90
« Reply #25 on: February 06, 2015, 07:56:53 PM »
Why did it fail at the base of the stem? Did they fail to put in the washer? How else would it have failed?
Red 90 Mille GT
« Reply #26 on: February 06, 2015, 08:33:47 PM »
If the washer was missing or the stem wasn't properly nutted down, yes.  Also, if the snout wasn't centered properly it can rub on the rim hole.  If the rim wasn't cleared of rust and scale around the rim hole (where rust often starts) it can abrade.  If the tire spun on the rim it can shear the stem.  That's why we have rim locks on dirt bikes.
But the shop decided either that it was a bad installation, or that they wanted to extend good will to the customer.  Either way, they took responsibility.  That's a good thing.   ;-T
Offline johnr
« Reply #27 on: February 06, 2015, 09:06:22 PM »
Tire spoons , a patch kit or spare tube , and some inflation method .
I like a push bike patch kit better than a spare tube. Much smaller to carry and will deal with more than one puncture.
New Zealand
« Reply #28 on: February 06, 2015, 09:26:11 PM »
Yeah , just make sure that your tubes will "take" a patch . Some modern tubes will not hold a patch . Don't ask how I know  ::)
No insult meant, Dusty, but the only time I've had a tube not take a patch was when I didn't scuff it up enough.  Are you sure you used something like sandpaper to get down to matte black rubber?
Offline johnr
« Reply #29 on: February 06, 2015, 09:35:42 PM »
Well carrying the tools to get a wheel off is a given need, find a way. Push bike tyre spoons are easiest to use and small to carry, but make sure you have three of them.
On my BSA R3 I used a a pump that worked off one of the cylinders by replacing a spark plug with it (I had shortened it and deleted it's gauge to keep it packed small)  They work on twins too but I'm not sure about injected bikes as I think you would get a fuel mix in the tube with them.
If you haven't got one how about a center stand? (Otherwise you will have to lay the bike on it's side.
If neither of those is in fact practical I would be looking for another bike in reality, as that one is obviously not meant to venture out of town. (away from a bike shop)
I too am not sold on tubeless tyres though that is what I have now. To date I've found that a puncture on a tube tyre was a pain in the proverbial and the cause of the emission of a number of expletives, not to mention dirty hands, but an easy enough process to carry out. The one time I tried it I was unable to actually use a tubeless tyre kit, and tyre changing is far harder.
Though I have used one successfully, the trouble with 'Tyre Pando' and such products that you simply inject through the valve is that they only really work on holes that are on the outside of the tube, where most, but not all of them, occur. It can be much harder to find the cause of the flat sometimes as it may not protrude out of the outside of the tyre and you don't get the opportunity to feel around for it. It will also lift off any patches that are already there.
At the end of the day I absolutely refuse to be stranded in the middle of nowhere, and no doubt out of cell phone coverage, by something as simple, common and easy to fix as a puncture. I'ts going to cost me some dosh to get the needful gear for tubeless tyres, but so must it be.
New Zealand
