Author Topic: What a night tonight deep in the woods.  (Read 29018 times)
Re: What a night tonight deep in the woods.
« Reply #30 on: February 18, 2015, 12:16:28 PM »
I'd guess your well water is around 50° to 55° down at the 120' depth.  That's about what I get here, summer and winter.  It's common for the water pipe from a well to be buried only a few inches from the surface in this area.
Offline redrider90
« Reply #31 on: February 18, 2015, 12:23:56 PM »
 It's common for the water pipe from a well to be buried only a few inches from the surface in this area.[/b]
Which is why I am running water in my shop and the house all night, all day  for the next few days.
Red 90 Mille GT
Offline Woodrow
« Reply #32 on: February 18, 2015, 12:25:10 PM »
Let me just jump in here (as I have nothing better to do)  , and say the good news is your water is running.   Im thinking this is bottom of winter here. Last year was killer for frozen everything.
Woodrow
-10F  here in Norhern Wisconsin
Online nc43bsa
« Reply #33 on: February 18, 2015, 12:54:07 PM »
Three times, I think.  Once to pick up the distributor, once when I brought the carb intake boots, and once to investigate the heating oil situation.  I must not be overly annoying if you underestimate my visits.  30° might be a bit on the high side.  It may hit 20% or 30% in spots.  The Internet tells me that 30% is about 17° ;D
Dumb question and slightly off topic, does anyone know what a road sign means when it says "8% Grade Ahead"?
Does that mean the grade is 8% at its max, or is it 8% average?
1990 MilleGT
Offline redrider90
« Reply #34 on: February 18, 2015, 12:54:14 PM »
Woodrow
My biggest fear from the ice storm 2 days ago that thankfully  petered out into snow and sleet was loosing my power for an extended period (got wood heat) and not able to keep the well running constantly Wed thru Friday.
The next 2 nights are going to keep all the  plumbers oh so very busy.
I think we going to be close to 0 Thursday night which in the 27 years I have lived here I have never seen.
Red 90 Mille GT
Offline Woodrow
« Reply #35 on: February 18, 2015, 02:18:18 PM »
If the power does go out for more than a a few hours ,  and you never know,  is it a option to go down into the water bunker room and drain pipes back ?
  Then if and when the power comes back at lest you have dry unfrozen pipes to fire up .
 At least your ready for the worst case .   At my house when we feel there is a good chance of being out of power
I fill up the bathtub with water , and a few 5 gal buckets .   Also need a supply of beer,  Kerosine and whatnot.
 I also have wood stove heat .
 Today its cold but tonight its going to be Gadzooks cold , if that air makes it down south it could freeze up a lot of water pipes .
Oof-Da
Woodrow
« Reply #36 on: February 18, 2015, 03:56:09 PM »
Supposed to be -13 degF here tomorrow night, which we're generally not really equipped for!   Another night to be up feeding stove and running water ..... !
Offline Late to the party
  • 1987 1000 SP2
« Reply #37 on: February 18, 2015, 04:16:32 PM »
I notice Vasco de Gamma conspicuously absent from the commentary. Do they have weather in Oz?
« Reply #38 on: February 18, 2015, 05:58:19 PM »
The predictions have gotten less severe lately.  A few days ago they were saying something like -10 here tomorrow night, and now WRAL's weather page is predicting 4°F for the coldest night this week.  That site shows Appomattox having a low of 0° tomorrow, so maybe it won't be quite as bad as you think.
Bill Hagan
« Reply #39 on: February 18, 2015, 06:26:55 PM »
Oof-Da
Woodrow
I drain the water from the whole system, turn off the well pump, and empty the toilet tanks whenever we leave the house for more than few days in cold weather. Takes a few minutes to do and undo. Presume it's worthwhile; even if not, a false sense of peace of mind helps  ... until reality hits.   ;)
We have a 17Kw (almost) whole-house generator, but when, as right now, the propane people guessed wrong and cannot keep up with deliveries -- we are at a "very concerning" level just now -- I worry about what would happen if we run out of propane.
Maybe you or others here know what happens -- besides the obvious power loss --when the propane tank hits empty.  Is there harm to anything mechanical, or is there an issue with an "air gap" in the line when refilled, restarted, etc.?  If so, should/can one do anything preemptive to prevent or mitigate damage?
C'mon spring. This sucks.   :'(
No.   ;D
Bill
« Reply #40 on: February 18, 2015, 06:32:13 PM »
Bill
I don't know of anything bad happening from running out.  I have a propane powered fork lift and I normally run it on a tank until it quits, and then swap tanks.  In fact, unlike gasoline engines, there is no extra cranking to start it after a full tank is connected.
Bill Hagan
« Reply #41 on: February 18, 2015, 06:49:32 PM »
Thanks.  Very helpful.
Kathi is always impressed with what folks know here.
The other day, she wondered aloud about something, then suggested I post it here as a question.
I didn't.   ;)
Bill
« Reply #42 on: February 18, 2015, 06:53:57 PM »
You're certainly welcome, Bill.
Now I can let my imagination run wild, trying to think of Kathi's question.   :D
Offline redrider90
« Reply #43 on: February 18, 2015, 09:55:27 PM »
No.   ;D
Bill
On modern propane heating systems the computer takes over and will reset over and over trying to fire the burners. Eventually any air would pass through and it will work.
On the older unit with a pilot light you hold down button and keep fire on it until it lights. Are there any old pilot light burners out there?
If you have a gas cooking stove just light a match and turn on the valve to get gas in the pipes flowing.
Red 90 Mille GT
Bill Hagan
« Reply #44 on: February 19, 2015, 03:13:06 PM »
Thanks.
Happy to report that the cavalry arrived today just as we feared the hostiles were going to get through our final protective fires.   ;D
In actuality, we still had just shy of a 20% cushion, but, as I am a nervous Nellie and the temps and the possible need for the propane-fired generator, I was still worried.   ::)
BTW, to compare for anyone interested in propane-pricing in this area, at least, this delivery was $2.349 a gallon.  I cannot say -- without hurling  :'( -- how many gallons went in.  But, it was last delivered to full on 27 Dec.  Really not bad, IMO, considering, tho we also have to factor in some our electric bill for that period as we have made some use of the oil-filled-radiator spot heaters.
On balance, very happy.  Hard to buy peace of mind.  Mine is much better now.
Now to the next thing to obsess over.   :D
Bill
Offline redrider90
« Reply #45 on: February 19, 2015, 08:18:44 PM »
Thanks.
Bill
I just had my first fill this winter. I have a small 320 gallon tank plus the shop. I paid $3.10 gallon. That is freaking crazy high. When I look at NC State website for propane it is showing $2.75/gal.
Red 90 Mille GT
Offline redrider90
« Reply #46 on: February 19, 2015, 08:49:18 PM »
This wood is gone.
 I had another cord by the front door when this picture was taken.
I am down 1/3 cord left at the front door.
Red 90 Mille GT
« Reply #47 on: February 19, 2015, 08:53:00 PM »
Harvey, you probably saw this photo, but here's the wood we had at the start of winter.  What's under the 10' x 20' canopy is gone now.  Luckily we made a "reserve pile" that's under a white tarp at the far end, and we haven't quite gotten to that yet.
« Reply #48 on: February 20, 2015, 10:07:23 AM »
Do you have water today, Harvey?  I was relieved when I found that I do.  I must have buried the pipe deeply enough after all.  When I put in the pipe and power wire, I ran an extra wire in case I came up with a use in the future.  After having the pipe freeze at the well head one winter when we had a 10° low, wired it to an outlet, and have a 75 watt lamp plugged in.  When it's very cold, I plug in the end at the house.
Offline redrider90
« Reply #49 on: February 20, 2015, 10:27:45 AM »
Yep we have water!! Yea. Shop is running also. I know for a fact the water line to the shop is shallow cause when I had the ditch dug deeper in my drive to keep it from washing over the road grader dug the pipe up!!
« Last Edit: February 20, 2015, 10:46:00 AM by redrider90 »
Red 90 Mille GT
