Author Topic: New to my '14 Griso  (Read 51053 times)
Re: New to my '14 Griso
« Reply #90 on: March 09, 2015, 04:07:13 PM »
Mine never had any problems at 4 and 6, it's currently running 6 and 8 due to the map it's running having been built on a bike with those clearances and the change in cam timing although small, is significant. For your machine I think it won't matter a jot.
Asylum
« Reply #91 on: March 09, 2015, 05:55:20 PM »
I'm guessing the manometer will connect where the rubber hose is on each side of the TB.
« Reply #92 on: March 09, 2015, 07:57:04 PM »
Or just remove the fittings and screw in your adapters.
Asylum
« Reply #93 on: March 10, 2015, 02:21:28 PM »
Last night I ordered the "Morgan Carbtune". Do you know by any chance if their adapters fit on the griso?
beetle
« Reply #94 on: March 10, 2015, 02:27:07 PM »
Yes.
Asylum
« Reply #95 on: March 10, 2015, 02:32:36 PM »
Beetle, would you recommend I put one of your maps once I get rid of the o2 optimizer.
beetle
« Reply #96 on: March 10, 2015, 03:08:56 PM »
Yes. I would wait until after the first service though. Unless you are doing your own services.
Asylum
« Reply #97 on: March 10, 2015, 03:22:40 PM »
Ya, I've been planning on doing it myself.
Is it necessary to replace the oil if it's been in my garage during winter even though it only has 250 kms?
« Last Edit: March 10, 2015, 03:40:00 PM by Asylum »
« Reply #98 on: March 10, 2015, 04:14:31 PM »
Nope, not unless you've been starting the motor for ten minutes at a time for months to 'Warm it up'.
And get rid of that poxy 'Optimiser'!
« Last Edit: March 10, 2015, 04:16:20 PM by Vasco DG »
Asylum
« Reply #99 on: March 10, 2015, 05:13:00 PM »
Pete, let me know if your interested in buying it from me. ;D
« Reply #100 on: March 10, 2015, 11:13:27 PM »
I'd rather stick red hot pins in my penis.
Offline Gootsz
« Reply #101 on: March 11, 2015, 08:15:10 AM »
I have VDST Centurian software setup. Guess I missed it but I did not see a "self learning" reset. Maybe called something else.
Please educate me.
Micky
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
THERE ARE NO WINNERS IN ROOM FULL OF LOSERS
Offline guzziownr
« Reply #102 on: March 11, 2015, 12:20:12 PM »
Undo the "hot" cable on your battery and count to ten.  Your computer will forget a bunch of stuff.
« Reply #103 on: March 11, 2015, 12:29:26 PM »
Please educate me.
Micky
No idea what it would be called with the Centurian set up but the function would have to be there. As stated above though the self learners can be re-set by disconnecting the battery or pulling the main fuse.
beetle
« Reply #104 on: March 11, 2015, 04:45:51 PM »
I don't think VDST has the trims reset.
« Reply #105 on: March 11, 2015, 05:22:58 PM »
Really? Good grief! OK, just disconnect the battery.
Offline Gootsz
« Reply #106 on: March 13, 2015, 06:52:29 AM »
done
pulled fuses wait a bit and replace. Same procedure for BMW Rockster.
Thanks all
Micky
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
