Author Topic: breva 1100 lever swap  (Read 6659 times)
chandlerslaughter
« on: February 18, 2015, 09:34:43 AM »
So, It's my first time changing the levers on my bike. How do you get the hardware out of the old ones and into the new ones? Namely the clutch lever. Thanks everyone.
Re: breva 1100 lever swap
« Reply #1 on: February 18, 2015, 10:18:58 AM »
Remove lever.
Undo grub screw in bottom of barrel that holds plunger. (heat may be required to loosen Loctite.)
Unscrew plunger from barrel.
Transfer barrel and plunger to new lever.
Install new lever.
Adjust depth of plunger.
Tighten grub screw to secure plunger in barrel.
Offline averb
« Reply #2 on: February 18, 2015, 07:42:37 PM »
Offline Tazturtle
« Reply #3 on: February 19, 2015, 01:58:59 PM »
Once the lever is off the bike, get that grub screw smoking hot first before trying to loosen it. If you manage to strip the internal hex (1.5mm) you will have a hell of a time getting it out.
Holding the lever in a rag and the barrel over one of those cheap little propane camping burners was all I needed. I had no need to heat the allen key as well! YMMV.
Once the grub is out, measure the length of the plunger that goes in to the master cylinder carefully (mine was 24mm long) as you will need to replace it in the same position. You will likely have a big dob of glue on the slotted screw head to clean off. Remember it is a reverse thread when you loosen it!
Kurt
2022 V85TT Evocative
2012 1200 Sport 8V Corsa SE
2011 V7 Racer #749
Offline Tazturtle
« Reply #4 on: February 19, 2015, 02:01:23 PM »
PS Welcome. It is great to see a 19 year old on WG! You are very slightly below the board average age...
Kurt
2011 V7 Racer #749
Offline Perazzimx14
« Reply #5 on: February 19, 2015, 02:26:40 PM »
Also measure how far out the plunger rod protrudes from the stock lever and set it to the same on the new lever. It's a good starting point.
AF1 racing in Texas also has plunger rods so you could also just order a new one and leave your stocker alone.
« Last Edit: February 19, 2015, 02:27:43 PM by Perazzimx14 »
