Author Topic: What ape do they employ to tighten filler caps at Mandello?  (Read 13290 times)
Doppelgaenger
« on: February 18, 2015, 01:57:03 PM »
Yesterday I completed the 13k mile service on my Breva 1100... but man was that transmission filler cap a pain to take off. I ended up using a hardened 8mm impact screwdriver bit stepped up to a 1/2 inch drive rachet to get it off after I ruined a few lesser tools in the process.
Is this a common occurence with anyone else's bike? what other items on these bikes are tightened so such massive torques?
Bill Hagan
Re: What ape do they employ to tighten filler caps at Mandello?
« Reply #1 on: February 18, 2015, 02:37:18 PM »
Actually, Piaggio has made Apes for years, but, this kind, named after the humble bee.  ;)
But, I, too, wondered about why my transmission fill plug was seemingly welded tight, tho it was a prior service, not a Mandellan -- or, more likely, just who did it the last time.
But, as soon as I saw how tight the foxtrotter was, I got out the Tool for All Seasons …
Then $9.95, now $3 more, I love it.  Some of the reviews here are a hoot: http://www.harborfreight.com/12-in-drive-25-in-breaker-bar-67933.html
Would like to have a vintage Ape, but that would be a first-class money pit within a week.
Bill
Edited to add that, upon reflection, it may be that no ape overtightened yours or mine -- tho it was still fun to defeat the guy with that breaker bar; makes me feel as if I've accomplished something with a tool.   ;D
Perhaps this is just a product of metallurgical processes over time, with varying temperatures and moisture helping that along?  The plug is steel; the casing, aluminum.  In my case, maybe I or a tech got lazy in a previous change-out and reused the crush washer?  Saved 25 cents.  ;)
« Last Edit: February 18, 2015, 03:45:39 PM by Bill Hagan »
Doppelgaenger
« Reply #2 on: February 18, 2015, 03:21:39 PM »
hmm I didn't even think of my breaker bar even tho I have one... dumbass move.
Still, when the cap let go I immediately said "Ok, which tool broke."
« Reply #3 on: February 18, 2015, 03:24:13 PM »
That's the reason I always check the fill plug before I use the drain plug.
Offline normzone
« Reply #4 on: February 18, 2015, 03:26:17 PM »
OOH, that's good advice, thank you. Yeah, my fill plug is why I bought one of those bars, although I've not tried it yet.
« Reply #5 on: February 18, 2015, 06:53:33 PM »
 Put a little andy sez on the threads before you put it back in.
« Reply #6 on: February 18, 2015, 08:26:02 PM »
Fill plug should always be out first for quick drainage.
Doppelgaenger
« Reply #7 on: February 18, 2015, 09:22:08 PM »
btw when you do change your transmission oil just make a chute into your catch pan out of aluminum foil or else you'll have to take a bunch of parts off your bike just to get to the drain and catch the oil without making a huge mess.
« Reply #8 on: February 18, 2015, 11:46:46 PM »
 bigga pan works mobetta.
« Reply #9 on: February 19, 2015, 12:59:37 AM »
No need, the gearbox has a breather.
crc
« Reply #10 on: February 19, 2015, 02:12:46 AM »
a single hex socket set is a good investment too, prevents a lot of slippage
« Reply #11 on: February 19, 2015, 07:08:58 AM »
I saw one of those in that Fiat ad with the Viagra pill.
Online leafman60
« Reply #12 on: February 19, 2015, 07:55:43 AM »
« Last Edit: February 19, 2015, 08:03:46 AM by leafman60 »
redrider
« Reply #13 on: February 19, 2015, 05:28:53 PM »
I always fret for a few miles after changing fluids along with crush washers. Copper ones are annealed and re-used. (Ah, strokers..)
Offline Nick
« Reply #14 on: February 19, 2015, 05:54:01 PM »
Here is the cheap/no frills model  ;D
Offline nikwax
« Reply #15 on: February 19, 2015, 06:39:19 PM »
Guido put loctite on
I could swear that loctite has never been used in the MG factory...or maybe they were just out when they were building my bike  ;)
2007 Breva 1100
LaMojo
« Reply #16 on: February 19, 2015, 08:48:34 PM »
I like the hand operated wiper.  Probably works better than the vacuum motors on my '40 chevy truck.
BigDave in PA
« Reply #17 on: February 20, 2015, 04:00:09 AM »
They were called "vacuum wipers" because they sucked.
« Reply #18 on: February 20, 2015, 05:27:30 AM »
Pretty sure this is the guy
