Author Topic: OEM V7 Stone crash bars  (Read 14141 times)
guzziv7fan
« on: February 18, 2015, 08:21:29 PM »
AF1 have the OEM crash bars for the V7 for $69.00 dollars.
My question is this crash guard OK? The price is odd to me.
Would like to see a picture of it mounted on a bike and maybe some comments good or bad.
The site show a rather vague picture of it mounted on an older smaller headed bike. The picture is chop showing little of the bike, hard to tell what it really look like mounted. Can't tell if it would clear the newer heads or not.
Harbor Freight price on this thing.
Re: OEM V7 Stone crash bars
« Reply #1 on: February 18, 2015, 08:59:20 PM »
I posted this response in the other thread. Solid one piece crash bar, I think Agostini is now making the OEM hence the 50% off price.
http://youtu.be/EHvQOSzpVTE
This video shows the installation, but they put it on BACKWARDS.
CAUTION : I would CALL them to make sure it will fit with the larger cylinders on the new V7's - 2013 and up.
« Last Edit: February 18, 2015, 09:02:34 PM by Cam3512 »
« Reply #2 on: February 18, 2015, 09:20:39 PM »
No, the video was just a mistake. They should only mount one way, the correct way.
I think you'll be fine.
Offline sib
« Reply #3 on: February 19, 2015, 08:20:13 AM »
I agree with all of the replies.  I got an OEM crash bar, part number GU973217200008, from RPM cycle, and put it on my '13 V7 Stone shortly after I got the bike in May 2013.  The bike looks like it left the factory that way.  Very solid, trouble free bar.  And, yes, it does work.  I've dropped the bike on both sides, and each time the bars protected the heads, with no damage to the bars, either.  Yes, I know, I'm a klutz.
One caution:  choose the side attaching bolts carefully.  If they're too long, you can drive the ends into the soft aluminum crankcase when you tighten them against their lock nuts.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Moto Fugazzi
    • Griso
« Reply #4 on: February 19, 2015, 10:03:27 AM »
I believe these are the ones. Check towards the bottom of the thread. http://wildguzzi.com/forum/index.php?topic=30214.0
I had a set briefly, and I believe I sold them to JAS67 (on this board) years ago. I think I had to pull a header off, and I didn't care for the way they looked on my bike once mounted. I then purchased the Breva 750 guards. Here's the similar version: http://www.af1racing.com/store/Scripts/prodView.asp?idproduct=60959
Ken
Here's the Breva bars on my bike, and you don't really notice them once painted. I don't know if they'll clear the cylinder on the newer models.
« Last Edit: February 19, 2015, 10:07:24 AM by Moto Fugazzi »
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
LaGrasta
« Reply #5 on: February 19, 2015, 11:08:34 AM »
i run the OEM guards, purchased from Newport Italian, also paid $69. I'm pleased with them, but they took some effort to wrap around and install, believe it or not.
Offline sturgeon
Re:
« Reply #6 on: February 19, 2015, 11:26:48 AM »
I've got the new-style Agostinis on my '14 V7S. They are a bit bigger to accommodate the newer valve covers/heads. My bolts were not too long, they were too soft. Two have snapped post-installation. Second one supplied by the dealer. At that point I gave up and bought my own better-quality replacements. So far so good.
And no, they did not snap due to ham-fisted tightening skills on my part.
Dyslexics Untie!
11 Yamaha WR250R
14 Moto Guzzi V7S
16 BMW R1200R
Offline drlapo
« Reply #7 on: February 19, 2015, 03:12:37 PM »
good deal; I ordered one also
it's already been shipped (same day)
Offline drlapo
« Reply #8 on: February 26, 2015, 09:12:33 AM »
the bar arrived today
looks good
no installation instructions
I wonder what the triangular plastic cover is for.
it won't fit at the top mount due to the postion of the voltage regulator
I noticed the lower mounting bolts are angled downward.  it looks like they replace 10mm bolts that are already in the frame and those bolts do not appear to be angled.
I won't know until i take it apart
« Last Edit: February 26, 2015, 01:40:29 PM by drlapo »
    • Griso
« Reply #9 on: February 26, 2015, 04:28:17 PM »
That plastic cover replaces the existing one above the voltage regulator. You'll see when you have at it.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
Offline sib
« Reply #10 on: February 26, 2015, 05:30:13 PM »
Ken
My '13 V7 Stone did not come with a plastic cover above the voltage regulator, and the parts manual for this bike doesn't show a cover.  I suspect that earlier bikes with the same, or a similar, frame did have a cover, and that at some point the manufacturer decided none was needed (probably not a cost-saving decision; the thing couldn't have cost more than $0.25 to manufacture).
    • Griso
« Reply #11 on: February 26, 2015, 07:56:42 PM »
Might as well put it on, anyway. There should be a spot above the VR that you can bolt it to. It's really just a filler piece, but might help keep debris off of the underside of the tank and some of the wires. If you don't want to install it, then you have an extra shuriken to throw around!
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
Offline drlapo
« Reply #12 on: February 27, 2015, 07:22:28 AM »
my 13 special does not have the cover but doee havr a smller plastic cover between the  frame rails and  a cable passes through the frame above the volt reg preventing the instalation of the larger cover provided with the bar kit.
it looks like the bar will fit  without the upper bolt spacers. has anyone mounted it without the upper spacers between the bar and the frame?
Offline sturgeon
« Reply #13 on: February 27, 2015, 03:24:51 PM »
Mine ('14 V7S) had/has no regulator cover, nor did the Agostini guard come with one. I did use the upper spacers, since it made little sense to me not to do so.
Dyslexics Untie!
11 Yamaha WR250R
14 Moto Guzzi V7S
16 BMW R1200R
Offline drlapo
« Reply #14 on: March 02, 2015, 07:29:13 AM »
mounted it Saturday without incident
I used the upper spacers as the bolts lined up better with them but the bar will go on without them
