Looking from Dual Disc Front Wheel
Topic: Looking from Dual Disc Front Wheel (Read 8260 times)
Hahnda
February 20, 2015, 04:24:50 PM »
I had an ad in the classifieds but didn't have any luck. Thought I would try here because how many people really look at the wanted ads? ???
Looking to turn and 850T single disc into a dual. Need a wheel from a T3, G5, Convert or similar. Actually I don't even need the whole wheel but might just be easier that way for the seller. Anybody have one available?
1949 GTV - 1948 Airone
www.scramblercycle.
com
Testarossa
Re: Looking from Dual Disc Front Wheel
Reply #1 on:
February 20, 2015, 05:32:39 PM »
You don't need a wheel, nor even a hub. Just longer through-bolts and maybe a different axle spacer.
Gone: 59 Piper Comanche 250, 69 Harley/Aermacchi 350SS, 71 Honda CB500/4, 74 Laverda 750 SF2, 91 Suzuki VX800, 50cc two-stroke scoot, 83 XR350R
fotoguzzi
vee git tooh soon oldt und too late wise -my Dad
Reply #2 on:
February 20, 2015, 06:30:49 PM »
can you show a pic of the disc you have? I'll then see if I have a matching one..
Hahnda
Reply #3 on:
February 20, 2015, 06:41:10 PM »
You're right. I dont need the rim or hub but I need the bearing / disc carrier, spacer, at least 1 disc but would take 2. Also need longer bolts but will use new ones anyway. Was thinking it might be easier for someone selling to just part with a whole wheel instead of being left with a rim laced to a hub.
I can get you pics foto but current wheel is totally disassembled. Maybe I have a before pic or can find one on the net.
www.scramblercycle.
com
Hahnda
Reply #4 on:
February 20, 2015, 06:57:33 PM »
Not mine but found these. Pretty much the same as a dual disc. Fairly straight forward conversion with the right parts.
www.scramblercycle.
com
guzziownr
Reply #5 on:
February 21, 2015, 07:49:00 AM »
If your current wheel is good you just need a custom spacer and longer bolts. Bob Nolan made one for my '75 Eldo but I went back to one disk with upgraded brake hardware. Not a complicated piece, it looked like a squared off aluminum doughnut.
fotoguzzi
Reply #6 on:
February 21, 2015, 09:03:18 AM »
Sorry, the one I had in mind turned out to be a rear disc down in the bottom of a drawer in my shop.
JoeW
Reply #7 on:
February 21, 2015, 09:51:41 AM »
You may not need anything except the disc, bolts and caliper. I've seen some T wheels with the correct spacer on the side with no disc. Take a close look at what you have, if it's identical to the disc side you're GTG. No need to make a spacer as in the Eldorado dual disc mentioned earlier, Eldorado's forks are 20mm wider than Tonti.
Joe Walano
Hahnda
Reply #8 on:
February 21, 2015, 10:17:05 AM »
No luck on that Joe.
www.scramblercycle.
com
