Author Topic: 2010 Stelvio fuel tank swap  (Read 6534 times)
Offline guzzibs
« on: February 27, 2015, 11:06:17 PM »
Hi to guzzisti.
 I have a 2010 Stelvio in Australia that I have sourced a second hand bare larger 32 litre tank for and now I,m chasing suggestions as to where to find a pump,fuel lines and rear tank cover to suit the swap?
Not that fussed with front fairings as I may redesign look to a naked front.
Does anyone know whether the pumps are a Bosch or a weber/marelli part?  Numbers? Will also require the large plastic ring that hold the pump in place.
Any suggestions on sources greatly appreciated,
Thanks Brian
Offline Unkept
Re: 2010 Stelvio fuel tank swap
« Reply #1 on: February 28, 2015, 05:58:33 AM »
Our friend Paul on the forum has done this swap. http://www.fastguzzi.nl/ http://www.guzzitech.com/forums/threads/2011-tank-on-2008-model.8130/
You can message him here on the forum if you'd like... http://wildguzzi.com/forum/index.php?action=profile;u=179
I know I didn't answer your question, but I bet $ Paul could help you.
-Joe
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #2 on: February 28, 2015, 04:46:43 PM »
Hi, I did two times such a conversion.
http://fastguzzi.nl/stelvio
Pumps are also in some piaggio scooters.
Left coil has to be positioned as the right one is.
Move ecu and fusebox. Ecu gets upside down
Back plastic is only new. Last new version is not painted I think. But all black.
I had same idea but ended buying all new plastics.
Paul
Daytona 1225, Stelvio 1151
Offline guzzibs
« Reply #3 on: March 01, 2015, 02:38:21 AM »
Thanks guys for the advise and suggestions.
Will chase a pump thru the scooter link to see if they are available and at what price.
Has anyone heard of a wrecked donor available for bits to suit?
Brian
Offline guzzibs
« Reply #5 on: March 01, 2015, 07:02:38 PM »
Hi Paul,
thanks mate for the links and info that's a great help.
The boys at Wildguzzi have put me onto a site on ebay called pinwall which although it does,nt have what I,m looking for does have a good range of general Guzzi
used spares just to pass on some info.
Brian
Offline Abbienormal
« Reply #6 on: March 01, 2015, 08:21:33 PM »
Actually the guys at Guzzitech told you about them.  ;D You can still call them or email them.  They are in Massillon, OH about an hour from me.  They are quite a large motorcycle salvage place and while most everything is listed on eBay not all. Or at least it used to be that way.  They sold me an ABS unit for $90 for my 2007 Norge among other stuff.
2007 Moto Guzzi Norge
1972 Suzuki TS 90
Offline guzzibs
« Reply #7 on: March 02, 2015, 12:53:00 AM »
AAAh yes ,sorry got my forums and boards mixed up.
Yep have emailed and asked if they have required parts or know where to source
My mistake,
 Cheers Brian
