Author Topic: tach signal wire NGC  (Read 8536 times)
« on: March 01, 2015, 07:14:19 PM »
Cross posted from the MZ list..
Well, they said it could't be done, so I tackled it with a grin.
I couldn't do it either.  ;D
Took the rattling tach apart, and a little gizmo (technical term) fell out. You could see where it had originally been soldered to the pc board and had a broken leg. Thought "aha" this will be an easy fix. Had Dorcia come out and help me solder it back on the board.. she's a whiz. Used to repair electonics, yada yada, but she didn't know what the gizmo was, either. At any rate, checked continuity after putting it back, looks good, glued it down with a hot melt gun so it wouldn't vibrate off again. Plugged it in, and.... nothin.   ??? I really did think it would work.
So. Anyone have a spare tach?
I've found the tach signal wire. How do I test it to make no shit sure that I have a tach signal?
Offline Semper-guzzi
Re:
« Reply #1 on: March 01, 2015, 07:50:36 PM »
Which bike is it off of?
2001 Jackal :)
Morizzi
Re: tach signal wire NGC
« Reply #2 on: March 01, 2015, 07:51:45 PM »
Hi Chuck,
Tacho signals are usually off one of the coils. When the points (or their electronic equal) open then the current stops flowing through the points and goes to the tacho.
Ignition on, voltmeter to the signal line then rotate the engine. You should see a reading after a couple of rotations.
Cheers
Rod
Re:
« Reply #3 on: March 01, 2015, 07:52:24 PM »
95 Skorpion tour.
« Reply #4 on: March 01, 2015, 07:53:24 PM »
Hi Chuck,
Cheers
Rod
Ok, thanks, Rod.  ;-T
« Reply #5 on: March 02, 2015, 10:14:37 AM »
Hmm, a guy on the MZ forum said
find a ham radio operator with an oscilloscope ..
that actually knows how to use it to look at it through a capacitor
for the pulses
that's above my pay grade. Necessary?
« Reply #6 on: March 02, 2015, 12:17:17 PM »
Do you have a meter that reads frequency?  It should work.
If you just want to see if there is something there, try an AC volt meter.  It won't read the correct value, but, it should give you something.
« Reply #7 on: March 02, 2015, 04:31:45 PM »
Thanks. I'll put it on AC and give it a try. Needless to say, I'm out of my league.. ;D
Morizzi
« Reply #8 on: March 02, 2015, 05:39:22 PM »
Chuck,
Not sure AC will work but if it does then good but the current only goes one way.
As i stated previously if the wire comes from the coil, not the ecu, then when the points are closed the power goes through the coils, some will still go to the tach though. Not sure what that voltage will be but it will be less than the full battery voltage due to feeding the coils too. When the points open the full voltage goes to the tach.
With a standard voltmeter/multimeter you are looking for change. If you have a spare electronic tach then just hook that up.Doesn't matter if its for a car or plane, 4,6 or 8 cyl. If you get a reading then its not the tach wire.
Rod
« Reply #9 on: March 02, 2015, 09:27:10 PM »
Yeah, it depends on the meter and how it measures AC.
Might even try just measuring using the DC volt scale too.  You're just looking for something.
« Last Edit: March 02, 2015, 09:28:27 PM by charlie b »
« Reply #10 on: March 03, 2015, 05:20:57 AM »
Chuck,
Rod
The signal comes out of the Yamaha magic box, whatever it is.  ;D There are three wires that go to the tach.. ground, positive,and signal. As long as I can't let the smoke out, I'll give it a try.
« Reply #11 on: March 03, 2015, 07:52:00 AM »
With all this low voltage stuff it is sometimes nice to have a logic probe.  Tells you if there is a signal, if it is pos or neg and some have an indicator for a pulsed signal.
