Author Topic: Breva 1100 fork springs  (Read 6542 times)
Offline egschade
« on: March 03, 2015, 06:51:04 AM »
I'm doing my spring prep work now on my '07 B1100 which will include a fork oil change. I've read about going to a slightly heavier weight oil - which I probably will - but I'm also thinking at 220# in my gear plus some stuff in the bags I could go with stronger fork springs. The front end dives a lot on anything more than mild braking and to get the sag right, I'm near max pre-load on the adjusters.
I've not found any threads on upgrades and am uncertain what to look for. Would B1200 sport springs do the trick or better to go aftermarket? Any advice will be greatly appreciated!
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Re: Breva 1100 fork springs
« Reply #1 on: March 03, 2015, 07:17:00 AM »
I have installed these in customers bikes, they work.
http://www.guzzitech.com/store/product/norgebreva-fork-kit/
Offline toma nova
« Reply #2 on: March 03, 2015, 12:09:07 PM »
I also bought heavier springs from Todd Eagan for my 1200 Sport.  Send him your weight with gear / luggage and he'll let you know the correct rate.  I went from stock to 10W fork oil, made a big difference. I posted a tech write up on GuzziTech with photos and specs.
2014 Stelvio NTX
2008 1200 Sport - sold
Offline EvanM
« Reply #3 on: March 03, 2015, 12:27:56 PM »
Another  :+1 for the Matris kit. Put that in, along with 20wt oil, and the front end is amazing. Night and day better than before.
2007 Breva 1100
Offline egschade
« Reply #4 on: March 03, 2015, 07:29:55 PM »
I see that I can order just springs for about 30% the cost of the kit. I'm not that aggressive a rider so if I go with springs and some heavier oil will I really miss the full kit?
AND, if I go with the full kit will my sock need upgrading as well?
Thanks for the info BTW. Internet search was pretty useless.
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline balvenie
« Reply #5 on: March 03, 2015, 09:09:56 PM »
          You could try just talking to the IKON people near you, before putting your money down. Their fork srings alone have transformed my Cali ;D
Oz
04 Cali
« Reply #6 on: March 03, 2015, 09:35:14 PM »
If you're happy w/rear shock why change it. Try just the springs & 15 weight oil. I just do what the customer wants.
My 98EV still has stock suspension, just heavier fork oil. I don't load it up w/lots of gear. Just tent, sleeping bag and a change of clothes. Always traveled light.
Offline EvanM
« Reply #7 on: March 03, 2015, 11:33:48 PM »
Yes. In my opinion you will anyways.
As for the rear, I upgraded mine, but I could have done without doing that.
2007 Breva 1100
cheekieduckie
« Reply #8 on: September 09, 2015, 04:06:42 PM »
Thought I'd share my recent work on the fork springs on my 2007 Breva.
I bought the bike with about 3500 miles and it currently has a little over 5k.  I made sure I rode it 'some' before tweaking.
The front suspension I found a little soft in terms of mid-corner wallow but yet harsh when it came to sharp edge (expansion gap type) bumps on the highway.  It seemed to (in my mind at least) to demonstrate the symptoms of soft low-speed compression with hard high-speed compression damping.  Or maybe I was just trying to talk myself into getting Racetech cartridge emulators :laugh:
Anyway, I thought to take it one step at a time.  Using Racetech's calculator and my 275lb heavy mass, I determined I needed a fork spring rate upwards of 1.05kg/mm.  FWIW, it looks like the Matris kit comes with 11.5N/mm (1.17 kg/mm) spring so it seemed like I was in the same ballpark.  This info came from http://www.guzzitech.com/forums/threads/breva-norge-fork-mods-1200-sport-info.8213/
http://japan.webike.net/products/21827041.html
The ID of the springs is 38mm and I picked FRSP S3732110, a 1.1kg/mm spring.
The original sag was 38mm w/6 turns out.  The original spacer/spring length was 205+280 mm = 485 mm
I cut the new spacer to 165mm.  Add the spring (315mm) and washer (1.8mm), the new stackup came to 482.5mm
The new spring didn't have a taper to it and so sits on the outside step of the preload adjuster, giving it another 2.5mm boost.
I filled it with 10wt Belray @ 400cc.  I drained approximately 480cc from each leg.
Here's a good link describing the process:
http://www.guzzitech.com/forums/threads/breva-v1100-fork-oil-change.2202/
Once re-assembled, I found I had to back the preload adjusters to 10 turns (was 6) to achieve the same sag.  I'm guessing this is due to the increased spring rate.  There was about 15 turns on the adjusters @ 1mm increment per turn so it didn't bother me too much.
Unfortunately I did put fresh PR4s on the bike as well....not an entirely controlled experiment.
Why the weird spring kit? It was also sized for my Futura...so that was a contingency in case this went horribly wrong   :undecided:
I've had it back out and in search of bumpy spots and curves with undulation.  So far I like it (only 50 or so miles).  It does appear a tiny bit harsher on low-speed compression but much better composed on high-speed bumps.  Overall less pumping of the handlebars and pretty happy around corners.
Just thought I'd share my 2 cents.
Ken
« Last Edit: September 09, 2015, 04:19:59 PM by cheekieduckie »
Offline guzzied
« Reply #9 on: September 09, 2015, 10:49:34 PM »
I installed the Matrix fork kit into my 2014 Norge as everyone said it worked great. Well for the price of the kit, I didn't find it worked much better than stock. Yes, the fork spring was much stiffer 11.5kg for my 220 lbs. with full gear. The bike still had too much fork dive for my riding style. So what comes in the Matris kit, fork springs, fork spring spacers, adjustable spring preload adjusters and plastic orifice's to control the fork oil which Matris states to use 10wt. The front fork sag is between 28-30mm. with the preload adjusters backed all the way out, the fork dive was better but I wanted it better, I pulled the forks again and changed the fork oil to 15wt, went on a 500 mile trip and while it is better, I would still prefer less fork dive. My next plan is to install the Race Tech Emulator and Race Tech springs as I feel the 11.5 kg springs are too stiff for my weight. To me, I feel the Matris fork kit is a band aid fix. Just put stiffer springs in with the stock 15wt or heavier 20wt fork oil and save yourself some money.
Just my thoughts, Mike
Mike Stewart
Sold  2000 Green V11 Sport
        2000 Jackal V1100 Cafe Project
        2002 Ghezzi Brian
        2002 California Special Sport
        2003 Rosso Corsa
Ride 2002 EV Sport Custom
       2003 EV Touring Custom
       2014 Norge 8V
cheekieduckie
« Reply #10 on: September 10, 2015, 10:32:09 AM »
Mike
Thanks for sharing, I think I'm headed toward the emulator path too.  I haven't disassembled my forks yet (not sure what the top of the piston looks like), but I'm thinking about trying FEGV S4301 and adapting as needed.
For what it's worth the FRSP S3732xxx series is available from .85 to 1.2 kg/mm.
Ken
