Author Topic: California 1100i rear light unit  (Read 4789 times)
Velton
« on: March 03, 2015, 05:16:30 PM »
Help please.
I have broken the rear light unit on my California 1100i 75th Anniversary Edition.
My question is - how to remove the plastic sort-of-T-shaped moulding which carries the indicators and twin rear lights?
After removing the actual number plate I could see a 10mm head / 6 mm thread bolt which came out easily
BUT
there remain 2 metal gizmos, painted cream to match the mudguard / fender which are clearly welded / brazed in on the bottom.
The tops seem NOT to be either hexagonal nut/ bolt heads or Allen /socket screws but cannot be seen from above because of the moulding.
(There are rubber grommets between these and the mounting plate on the mudguard.)
How do you get them off / out?
Offline Scott DeRoss
Re: California 1100i rear light unit
« Reply #1 on: March 03, 2015, 06:54:04 PM »
I hope this helps. Bottom of the page on this link.  California 94-97 pdf  Page 57   Looks to be a snap ring or E clip. AND MANY OTHER PARTS MANUALS TOO!
http://www.tlm.nl/en/parts/new-parts/partsmanuals/
« Last Edit: March 03, 2015, 07:15:34 PM by Scott DeRoss »
2007 Vintage (Vinnie)
2017 V9 Roamer (Sunny)
1-76 & 3-78 Robins
1975 Honda CT90
1979 Beneli G2 moped
75 850t wifes (Plum Crazy)
79 Honda Ct70 (restored)
MGNOC L-661
Never take life so serious you won't get out of it alive
