Author Topic: (Little Guzzi Content) Perception of heights  (Read 14090 times)
kirby1923
Re: (Little Guzzi Content) Perception of heights
« Reply #30 on: March 06, 2015, 10:16:27 AM »
After thinking about it and talking with colleges here of the same ilk, I have to say that in my whole adult life I have never had any fear of:
Falling off a mototbike or crashing same
Falling out of the sky or crashing an aircraft
Crashing an automobile.
Falling while rock climbing
That always happens to "the other guy".
None of the above even crossed my mind
Counter productive to the mission at hand.
mike
Offline normzone
« Reply #31 on: March 06, 2015, 10:41:58 AM »
Some decades ago I was doing a Form 5 ride in a C182. At 400 feet on takeoff the check pilot reached across and pulled the keys out of the mag switch. I turned 180 and landed on a taxiway. That night I got curious about what might have happened if I'd tried a steep turn to reach the runway at that speed. Next day I climbed to 5000 feet AGL, set up 85 knots and pulled a 45 degree bank. I spun, and took 1500 feet to recover.
Great story, good check pilot.
[ Without knowing it, we have all seen the "visual cliff" effect/instinct demonstrated by infants who are accomplished crawlers/creepers.  Briefly, when they are placed on an unfamiliar floor and allowed to roam, they will come to a quick halt when they arrive at a transition in the floorcovering.  The instinct is extremely strong when the transition is from a patterned and/or rough flooring (wood, carpet, etc.) to a flooring that is shiny or that gives no visual clues that it is solid.  The youngster may sit at the transition and, when given time, reach across the transition and pat the new surface with one hand.  Those who are pretty bold may eventually cross the transition and try it out.  Those who are not so bold may turn around and "flee." ]
And THAT explains why I've seen that same behavior in horses before - they're crossing a bridge, cruising along just fine, and all of a sudden a white line in the middle of the road makes them flinch and look for a way out of what you've asked them to do.
kirby1923
« Reply #32 on: March 06, 2015, 10:50:50 AM »
« Last Edit: March 06, 2015, 03:43:37 PM by kirby1923 »
