Author Topic: Stelvio ECU rubber boot install  (Read 4927 times)
Offline tonyduc
    • Staccato Cycle
« on: March 09, 2015, 04:37:51 PM »
I am installing a rubber boot protector for the ECU per this recall notice
Protection of electronic control unit cod.883968
The procedure in this post http://www.guzzitech.com/forums/threads/ecu-location-and-removal.3165/ shows ECU removal but not how the boot goes over the ECU.
Does anyone have a procedure on how the boot is positioned over the ECU then mounted?
I can have a dealer do this but I am 2+ hours away and I am doing an OEM heated grips install anyways (requiring partial removal of the side panels), so might as well do it myself.
Tony
2011 Stelvio -white
1976 T3
1996 Ducati 900ss CR
2017 Yamaha XT250
1966 Ford Bronco
Former
1969 Ducati 450 SCR
1984 California II
07 Honda VFR
71 CL350
08 Ducati 848
05 Ducati M620
80 Yamaha XS650
73 Suzuki TC100
Offline pauldaytona
    • Paul's fast Guzzi Page
Re: Stelvio ECU rubber boot install
« Reply #1 on: March 09, 2015, 04:49:48 PM »
I suppose you have the small tank, then it goes on like a hoodie.   I took different approach with my 2012. I put it on upside down, I think wheel spray might do more harm than a bit of rain, if it comes there at all. I made a i/2 inch hole in bottom so it won't fill up with water, in case...
 do what you think is best.
Paul
Daytona 1225, Stelvio 1151
