Author Topic: spare loop frame fork top nut to make a puller tool?  (Read 5161 times)
Offline tpeever
« on: March 09, 2015, 11:47:16 PM »
Does anyone have a spare nut for the top of loop frame forks that they would be willing to sell or donate to me? I will be assembling my V700 forks soon and need to make a puller tool to pull them up into the triple tree. I have the long threaded shaft portion of the tool but don't have a plug of the correct size and thread form. If I drill out an old nut I can make the plug that goes into the top of the fork stanchion and save myself 50 bucks buying the factory tool. Thanks.
Tobin
2024 Suzuki V-Strom 800
1979 Kawasaki KZ1000 LTD
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1974 Norton Commando
1968 Moto Guzzi V700
1967 Triumph TR6C
1961 Norton Dominator
Online Perazzimx14
Re: spare loop frame fork top nut to make a puller tool?
« Reply #1 on: March 10, 2015, 07:55:05 AM »
I just ripped a 2 x 4 down to a cube a little bigger than the I.D. of the for tube about 24" long. Screwed it into the threads and viola a cheap disposable fork tube puller. Or if you can fine a dowel rod at your local hardware store in a diameter thats close it will wor as well.
« Last Edit: March 10, 2015, 08:16:39 AM by Perazzimx14 »
Offline Greg Field
  • The Signs Foretell the Rise of a Guzzi Lama . . .
« Reply #2 on: March 10, 2015, 04:48:50 PM »
I'm in WA and have a puller I could lend you.
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #3 on: March 10, 2015, 05:23:09 PM »
Greg's offer is much more economical, but for a backup plan
http://www.harpermoto.com/loop-frame-fork-tube-installation-tool.html
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Offline tpeever
« Reply #4 on: March 11, 2015, 09:33:36 PM »
Thanks everyone!! Lots of great suggestions there. Appreciate the ideas.
Tobin
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
Online pehayes
« Reply #5 on: March 12, 2015, 12:06:34 AM »
I think I might have one.  Check in the morning.
Online jrt
« Reply #6 on: March 12, 2015, 08:15:49 AM »
Doesn't have to be a loop frame top bolt.  Any 29X1mm will work- I made one from an abused fork cap  I got off a G5- just cut the hex off so it fits through the triple trees.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Online pehayes
« Reply #7 on: March 12, 2015, 04:55:03 PM »
I have one.  A few upper threads are lightly buggered but could be cleaned with a Dremel or just ground away.  I think you could turn it into the fork tube about 10X before reaching one of the bad thread crowns.  That would be more than enough for your puller task.  The hex has been ground away mostly.  I could clean it up a lot in my lathe and finish the proper removal of the hex on the top.  Do you have lathe access?  Want this one?
