Author Topic: Forkupgrade: FAC + progressive springs = bottom out ?  (Read 19072 times)
Offline redrider90
Re: Forkupgrade: FAC + progressive springs = bottom out ?
« Reply #30 on: March 14, 2015, 02:22:48 PM »
I had the same problem with my V7C.  It has a mupo progressive spring kit with an emulator.  I started with 10W oil, but had too much dampening.  I wound up using Motorex 2.5 weight oil and worked great.  No bottoming, and perfect dampening.  I wanted to be able to abruptly compress the forks and release them.  They should go down, come back up, and then settle a few millimeters.
T5 only uses oil/ATF for lube.
Red 90 Mille GT
Offline StubkierDK
Solve :=)
« Reply #31 on: March 16, 2015, 02:40:55 PM »
Hey All
Practices makes perfect - after having reduced the removal, disabling, check, resembling and remounting to 60 minutes I finally found  the error :-)
The upper forktubes are to long - this was the last part i checked. As mention I ordered a set of new ones - but forgot to check that they had the same length as the old. Here you can see the difference between the two
So Charlie B perhaps you should check the length of yours?
Now  :bike :bike :bike
Moto Guzzi 850 T3 @ 1978
Offline JBU
    • www.joelurruty.com
« Reply #32 on: September 09, 2016, 03:28:12 PM »
Hey StubklerDK,  How is the suspension now that you have the new fork tubes?
What is the length of your travel now?
One last question what is the correct length of the fork tubes?
My T3 seems to bottom out and make an awful noise.  I have the wurth springs and FAC dampers.  I am going to dissemble my forks soon and was curious to know if you finally fixed the problem.
JBU
Red Dog
« Reply #33 on: September 09, 2016, 04:03:33 PM »
Just a quick add on here.
A long time ago I rebuilt the forks on Red Dog (my avatar) I had never been into forks before except on the old ElDorado I hit the deer with, now there was a complicated front end compared to the T's.
I went to MG Cycle's site to order & found two different length springs, fork tubes & maybe dampers (been too long to remember).
I called them and asked about it & was told that early T's had shorter tubes & later models had longer tubes & all the internals had to match.
So I pulled mine apart & measured & it was the shorter set up.
That was the best handling Guzzi I have ever been on.
Since then I have seen many different combinations on T series Guzzi's: Single springs, double springs, long & short tubes, different lengths on the rods.  I have often wondered why there were so many different set ups.
Offline JBU
« Reply #34 on: September 11, 2016, 04:34:40 PM »
I had some time today to take the forks off the bike.  It looks like I may have assembled the wirth springs the wrong way.  Can someone please let me know which way the spring needs to be oriented?  Right now the tightly wound part of the spring is on the bottom.  From reading this posts it seems like it should be the other way around.  I am correct?
JBU
Offline StubkierDK
« Reply #35 on: September 12, 2016, 02:31:47 AM »
I went back to the old (short model) and it is handling fine :)
Offline chuck peterson
« Reply #36 on: September 12, 2016, 06:17:15 AM »
I've had the 200cc lock up the fork travel, while making it the 65 was right...
Guzziology has a lot to say...I believe the G5/Vert oem dual springs and longer travel was a common refit to T/T3...or aftermarket Wirth or Progressive springs, fac dampener...just had to raise the forks in the triple a touch so the center stand would work again...and to sharpen the steering back a bit
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline JBU
« Reply #37 on: September 12, 2016, 06:47:10 AM »
well i will be putting the forks back together with the springs in the correct direction this time and see what difference it makes.  I was probably distracted when I assembled them the first time.
JBU
