clutch slave cylinder
Topic: clutch slave cylinder (Read 3877 times)
dxhall
March 11, 2015, 09:09:55 PM »
I had to remove the clutch slave cylinder on my 2003 Sport Naked to replace the hydraulic line. As I was taking it off the transmission case, something fell out. Under the lift I found a single ball bearing which could, I suppose, fit into the cup in the clutch rod assembly. The parts book doesn't show it, though. Anyone know if there's a single ball bearing between the piston of the clutch slave and the rod assembly?
guzzisteve
"Just Ride It"
Re: clutch slave cylinder
Reply #1 on:
March 11, 2015, 09:46:15 PM »
Not unless someone put one there.
dxhall
Reply #2 on:
March 11, 2015, 10:47:49 PM »
Hmm. Where is there a loose ball bearing on this bike? I can't think of any...
twhitaker
Reply #3 on:
March 12, 2015, 06:13:58 AM »
About 5mm in diameter? Does the front brake light switch use one?
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Reply #4 on:
March 12, 2015, 06:19:16 AM »
Absolutely NFI!
5mm doesn't snag with anything I can think of either quickly or slowly?
