Author Topic: Quick spec needed from you guys who actually know stuff  (Read 13206 times)
« on: March 13, 2015, 12:24:29 PM »
Engine is an 03 hydro.  With the bike straight and level, headlight off, water pressure correct, brakes oiled, color codes matched and synthetic bean oil in the bar end weights, What number do I want the needle on my adjustable fuel pressure regulator pointing at?
Offline mtiberio
    • TiberioRacing
Re: Quick spec needed from you guys who actually know stuff
« Reply #1 on: March 13, 2015, 12:25:22 PM »
x > 0
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline youcanrunnaked
« Reply #2 on: March 13, 2015, 12:28:28 PM »
Depends on the level of your blinker fluid and the torque spec on your muffler bearings.  ;)
« Reply #3 on: March 13, 2015, 12:29:04 PM »
42, ask the mice.
« Reply #4 on: March 13, 2015, 12:36:20 PM »
42, ask the mice.
 Yep  :+1 ;D
« Reply #5 on: March 13, 2015, 12:57:47 PM »
Pi
190 Octane
« Reply #6 on: March 13, 2015, 02:57:32 PM »
the Bailey
« Reply #7 on: March 13, 2015, 03:02:20 PM »
it depends, are you using Ford or GM antifreeze?
Offline slopokes
« Reply #8 on: March 13, 2015, 04:52:41 PM »
 :+=copcar  is the rite weight oil in the sump :BEER:
« Reply #9 on: March 13, 2015, 05:02:24 PM »
3 bar
« Reply #10 on: March 13, 2015, 05:09:44 PM »
It won't work, you need whale oil in the bar end weights. Probly explode just sitting there. Call 911 and hide under the bed.
« Reply #11 on: March 13, 2015, 05:15:36 PM »
  It won't explode just because you don't have whale oil.  You can substitute oil rendered from Texas armordildos.
« Reply #12 on: March 13, 2015, 05:22:28 PM »
If it wasn't for the Friday the 13th part I'd complain about the quality of wit today.  Surely you can do better than whale oil . . ..  :-\
Thanks for 42.  I knew it was supposed to be In the 2.5-bar area but wasn't sure on account of there are no 2.5 bars in town anymore.  They all serve full strength.
Online balvenie
« Reply #13 on: March 13, 2015, 05:23:36 PM »
               Best grin I've had all morning you blokes ;D ;-T
Oz
04 Cali
« Reply #14 on: March 13, 2015, 06:35:33 PM »
Pi
Speaking of which -- tomorrow is pi day.  That doesn't happen too often.
 . . . and I found a valid example of division by zero!
When my bike is stopped (zero road speed) the engine 'stalls' (won't continue to accelerate) with the torque converter spinning at about 1800 rpm.  So at maximum slip, the math looks like this:  1800/0.  Blows the mind.
« Reply #15 on: March 13, 2015, 09:25:49 PM »
I guess you're one of the luddites who won't subscribe to the use of the hose clamp. You wouldn't need to check or confirm the setting if you were a "clamper".
Todd.
« Reply #16 on: March 14, 2015, 12:47:07 AM »
This way is more fun, AND I don't end up with an unknown quantity in my new construction.   :)
But I do have a hose clamp on my external filter, just for folks who think I need one.  It also hold the karma bell on the bike.
« Reply #17 on: March 14, 2015, 04:23:04 AM »
I believe you're gonna need a hose clamp on the nut sac housing retention assembly. Otherwise it's likely to blow up just sitting there. Call 911 and hide in the closet. :beat_horse
« Reply #18 on: March 14, 2015, 08:34:16 AM »
Did anybody call 911 ?  I'm going to hide in the tire pile !   I missed that there was a real question in the post until this morning. I still think it will explode at some point!
« Last Edit: March 14, 2015, 09:01:33 AM by john A »
« Reply #19 on: March 14, 2015, 02:46:41 PM »
Yes, you seemed to be in distress, so I called 911 right after I read it.  I told them it was the John in Wisconsin, and then they didn't want to go at all.  So I told them you wanted to buy tickets to some policeman's balls.  I'da thought they'd be all over it . . .
MotoGoosy
« Reply #20 on: March 14, 2015, 04:36:37 PM »
You need at least 3 pints of oil from the anal sacs of a Mongoose.  Hard to get, but well worth it.  Let me know how that works out for ya.
« Reply #21 on: March 14, 2015, 06:15:16 PM »
Hmmm.  Could  I substitute 4 pints from a canadagoose?
MotoGoosy
« Reply #22 on: March 14, 2015, 07:25:59 PM »
No, not same.
« Reply #23 on: March 14, 2015, 07:40:45 PM »
.  Thanks, I'm still in the tire pile . They swat teamed the place this afternoon, last I saw of the wife she was cuffed and stuffed in a cruiser.  I'm safe though......
« Reply #24 on: March 15, 2015, 03:36:15 AM »
Still snowed in up there huh? ;D
« Reply #25 on: March 15, 2015, 07:50:21 AM »
Actually not anymore ! The wife and I are going to go for a ride today, maybe sanity will return after all!
« Reply #26 on: March 15, 2015, 04:07:09 PM »
Here it is mid-March and we're finally getting some snow.  It started yesterday.  There's a few slushy inches on the ground, but it's really too warm to last.  Temps go back to the 40s tomorrow.
