Author Topic: Neutral light flickering on my 09 Norge  (Read 6193 times)
Offline OlderSlower
« on: March 16, 2015, 06:52:25 AM »
First decent day here in Ohio, so I fired up my new to me Norge and the neutral light is flickering, sometimes off and sometimes on for a bit.  Any ideas where to look first?  Much appreciated.  BTW I personally have electrical demons that follow me, so I hope I didn't ask for trouble by getting an Italian bike...
2009 Norge, Staintune, Helibars, lower pegs, Russell seat, Matris fork kit and shock, more to come...
2008 Triumph Bonneville
Cheese
Re: Neutral light flickering on my 09 Norge
« Reply #1 on: March 16, 2015, 08:08:43 AM »
Just a guess; Thoroughly clean your grounds and see if it helps.
Peter
« Reply #2 on: March 16, 2015, 08:17:39 AM »
Tighten the connection on the back of the transmission.
« Reply #3 on: March 16, 2015, 02:52:02 PM »
Does it flicker in gear or while in Neutral?
Offline OlderSlower
« Reply #4 on: March 16, 2015, 05:14:24 PM »
It only flickers while in neutral.
« Reply #5 on: March 16, 2015, 06:59:54 PM »
Probably just a dirty contact in the gearbox then, test it by jumpering to chassis at the gearbox end, it should go on steady, if it still flashes it's at the light end. Actually when I look I see it goes into the ECU, I doubt it would be the problem.
http://www.thisoldtractor.com/guzzi007/schematics/2007_Norge_ABS.gif  item 32
I'm not sure where the switch is located on the Norge, others it's behind the starter. I'm sure someone will post a photo.
I'm pretty sure you will be able to remove and clean it without draining the oil.
« Last Edit: March 16, 2015, 07:10:16 PM by Kiwi_Roy »
Offline OlderSlower
« Reply #6 on: March 16, 2015, 07:28:24 PM »
I appreciate the help and any advice as to easiest way to get at the connection.
Offline MLR
« Reply #7 on: March 16, 2015, 07:34:11 PM »
My 2012 Norge did the same thing & it was just a loose connection on the switch. It's very difficult to get to though, on the rear right side of the tranny, right up against the frame. I just pressed down on it firmly with a long screw driver and turned it back & forth a few times & that did the trick.
Offline OlderSlower
« Reply #8 on: March 17, 2015, 06:23:27 PM »
Thanks to all who shared ideas, I will try to get it fixed this weekend!
« Reply #9 on: March 17, 2015, 06:35:22 PM »
Sort of above where the drive shaft comes out of the rear of the transmission. Very hard to get to.
« Reply #10 on: March 17, 2015, 08:11:22 PM »
Sits under the airbox, easy w/very long pair of needle nose pliers. Crimp closed a bit on female connector and slide back on. It is also under a rubber boot I think.
