Author Topic: Fuel Management Program  (Read 4015 times)
Gray Goose
« on: March 17, 2015, 06:07:20 PM »
I'm changing the stock exhaust on my 1998 V11 EV and replacing it with Lafranconi Competizione silencers.  I can't find a fuel management program designed for the '98.  Any advice?
Re: Fuel Management Program
« Reply #1 on: March 17, 2015, 06:39:38 PM »
Well w/it was new you could get a few different chips available. That was then.
I have a Techlusion fuel box on mine, only adds pulses to the fuel map. Mine has open airbox also.
Offline delrod
« Reply #2 on: March 18, 2015, 07:23:01 AM »
I use my J O B very effectively for a fuel management system it has a very effective monthly threshold (non-adjustable)
Doug in Pittsburg KS
2003EVT
« Reply #3 on: March 18, 2015, 07:34:22 AM »
welcome to the forum Gray.. advice? put on the pipes and try as is..
on the computer box is a trim dial that can be adjusted  (for idle and just off idle) if needed.. It's under a plastic cap.. don't turn it more than 1/2 turn and then ride so the change can be computed. if you have access to a Co sniffer it can help you to set the dial.
stay away from the power commander unless you just can't get a good tune and save the money for gas and tires.
the Guzzi FI supplement is available from Greg Benders site at thisoldtractor.com
« Last Edit: March 18, 2015, 07:35:43 AM by fotoguzzi »
