Author Topic: All you V11 Sport/Lemans guys.... Why the backfiring?  (Read 7291 times)
Offline ritratto
« on: March 18, 2015, 11:24:18 AM »
Hey everyone.... My '03 Lemans just recently started backfiring when I throttle down. Whether high or low rev, seems to make no difference, except how loud it is. If I pull in the clutch, it stops, but would feel better if it stayed under power instead of free-wheeling.
What happened and can it be fixed?
Stock exhaust system... nothing fancy going on here. Help!
1978 G5
1998 Centauro ( oppsidaisy!)
2003 V11 LeMans
Re: All you V11 Sport/Lemans guys.... Why the backfiring?
« Reply #1 on: March 18, 2015, 11:34:04 AM »
Air leak in the exhaust somewhere. Does it have a front crossover that loops down under the alternator cover? Is this loose?
« Reply #2 on: March 18, 2015, 11:39:43 AM »
I'd check the front crossover for leaky gaskets at the joints with the headpipes.
jomarti3
« Reply #3 on: March 18, 2015, 11:50:17 AM »
We had a crack in the front crossover area on a 2004 LeMans.  Fixed, happened again.
« Reply #4 on: March 18, 2015, 11:56:52 AM »
Best thing to do for that problem on the '03/'04 Sport/LeMans is replace the headers that delete the front crossover.
Offline ritratto
« Reply #5 on: March 18, 2015, 12:19:59 PM »
I got some billit aluminum gaskets for the crossover pipe from MPH and fitted them about a year ago and no known leaks there any longer. Crossover is tight. Is there another culprit?
1978 G5
2003 V11 LeMans
« Reply #6 on: March 18, 2015, 12:26:48 PM »
Check the exhaust gasket at the head, and make sure the nuts are tight on the retaining collars.
Otherwise, I'd be looking for cracks in the system.
« Reply #7 on: March 18, 2015, 01:05:36 PM »
Yup, air leaks are the commonest cause. Check every joint in the system and then go hunting for cracks.
Offline ritratto
« Reply #8 on: March 18, 2015, 01:12:35 PM »
Thanks guys... will have another look over it all tonight!
1978 G5
2003 V11 LeMans
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #9 on: March 18, 2015, 05:05:02 PM »
That "billit aluminum gaskets for the crossover pipe" make that it is tight, but also inflexible, and since the heads dance their shaking dance, chance is that there comes a crack in the stainless pipes. Now or later
Paul
Daytona 1225, Stelvio 1151
Offline Unkept
Re:
« Reply #10 on: March 18, 2015, 06:42:48 PM »
Intakes rubber cracked or loose?
