Author Topic: Valpolini rocker cover gaskets for square head 2V big blocks...  (Read 9760 times)
Got some in today. Brilliant! They are the metal with coating type. Same material and type as the small lock rocker cover gaskets. They can't tear and will almost certainly be re-usable sever times. I'll post up a pic but they just look like a RC gasket.......
Offline Phang
Re: Valpolini rocker cover gaskets for square head 2V big blocks...
« Reply #1 on: March 18, 2015, 11:22:46 PM »
This is so timely, I am about to order the gasket for the new to me 2000 V11 Sport.
2000 V11 Sport (Green)
1973 V7 Sport (Green)
« Reply #2 on: March 18, 2015, 11:25:12 PM »
Over here the importer has given them a non Guzzi part # but they aren't pricey. If you can't find them on line I can send you a pair.
Offline Phang
« Reply #3 on: March 18, 2015, 11:37:38 PM »
Thanks Pete, a close up photo of the gasket will be helpful.
Will let you know if I can't find them.
« Reply #4 on: March 19, 2015, 12:10:28 AM »
If people in Oz are getting gaskets from a dealer ask specifically for your dealer to order that part number otherwise you'll probably get the shitty earlier ones!
Offline Phang
« Reply #5 on: March 19, 2015, 01:02:39 AM »
Thanks Pete.
I just sent an email to you regarding the rocker cover gasket and Roper plate  :)
Offline jacksonracingcomau
« Reply #6 on: March 19, 2015, 02:15:40 AM »
I reckon it's even clevererer
Looks like it does roundies & squaries, only 32 years after the event !!!
Could've saved a lot of stock for dealers in that time, Guzzi themselves never bothered, more coin in selling more stock !!
Try one, let us know
MH
« Reply #7 on: March 19, 2015, 04:26:40 AM »
I hadn't even thought about that. We're off to Long Flat for the weekend but I'll dummy 'em up on our hungover return!
« Reply #8 on: March 19, 2015, 08:05:44 AM »
i suppose the twin spark plug heads are different.
« Reply #9 on: March 19, 2015, 10:23:38 AM »
so far, so good with these:
« Reply #10 on: March 19, 2015, 11:06:39 AM »
I don't think so Wayne. They are now listed specifically for the Breve/Norge/Sport/Bellagio models which are all twin plug engines. The plugs are beneath the level of the rocker covers.
« Reply #11 on: April 08, 2015, 04:27:23 AM »
Did they fit ?
Offline brlawson
« Reply #12 on: April 08, 2015, 07:10:11 AM »
These are great for hydraulic lift engines.
B. Lawson
Madison, AL
'72 Suzuki Titan 500
'77 Yamaha RD400
'79 BMW R/65
'03 California Titanium
'10 Stelvio ABS
2000 v11 Sport
« Reply #13 on: April 09, 2015, 12:14:01 AM »
I think they'll work on Roundies too Martin.
« Reply #14 on: April 09, 2015, 01:41:22 AM »
might even work round boxes on square heads without adaptor plate, will try, good find if they do,
lot of gorilla snot in that pic !!
Offline Dick
« Reply #15 on: April 09, 2015, 04:06:19 AM »
Unless they are super thick, or you grind away some of the valve cover, the inner head bolt cap will interfere with the cover.
« Reply #16 on: April 09, 2015, 05:43:20 AM »
No, lot of spiderwebs. It's the cover off my 'Letterbox' motor.... :D
