Author Topic: Yet Another TPS Substitute  (Read 4988 times)
« on: March 20, 2015, 03:59:52 PM »
I came across this rotary positioner from Bourns a company that specializes in this type of thing.
The beauty of a non-contacting device, it doesn’t have sliding parts to wear.
If you look at the data sheet you will see that there is only one sheet to cover the whole range of angles
I think we would need
10 – 90° of rotation
Counter clockwise to increase
You would need to file the shaft flat to fit the throttle body
It doesn’t have a spring to take up the slack
http://www.digikey.ca/product-detail/en/AMS22B5A1BHASL109N/AMS22B5A1BHASL109N-ND/4995629
Offline Caffeineo
  • Guzzi B00b
Re: Yet Another TPS Substitute
« Reply #1 on: March 21, 2015, 09:28:29 AM »
If it was "plug-N-play" I'd give it a shot. But I have had some real.........challe nges setting the TPS and as it is running good now I think it is best left alone.  ;D
However, I set the TPS on my 2014 Husaberg FE501 and it was easy. The movement was very linear and easy to get the right #. Not like the Bassa where a tiny tap moves it 30-40%.  :-\
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Offline jmac851
« Reply #2 on: March 21, 2015, 03:33:58 PM »
Maybe they could make one if you send them yours or another sample.  I saw this non contact TPS used to rebuild a Mercedes throttle body on one of the car shows. It was made for the car.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
