Author Topic: Busted V11 Cross Over  (Read 5352 times)
Bones1300
« on: March 20, 2015, 07:30:10 PM »
The cross over on my 2000 Jackal broke at the weld. I am planning on just building a new crossover with out the baffling, my question is will there still be enough back pressure? It has the stock pipes on it.
Offline Mark West
Re: Busted V11 Cross Over
« Reply #1 on: March 20, 2015, 07:42:39 PM »
Get a crack-proof crossover from guzzitech.com. If all you do is switch to a straight H-pipe, it probably won't effect the fueling much.
Mark West
Hollister, CA
MGNOC L-752
Offline Kent in Upstate NY
« Reply #2 on: March 20, 2015, 07:51:03 PM »
I've had an H pipe from Fast by Ferraci on my 01 Cal Special for years. Works a treat.
« Reply #3 on: March 20, 2015, 08:49:56 PM »
I use the one without the muffler in the cross and I cut the crossover in half and put a splice in with band clamps. Helps with alignment so it's less likely to crack.
« Reply #4 on: March 20, 2015, 08:52:43 PM »
It's not that kind of V11, and not that crossover.
« Reply #5 on: March 20, 2015, 08:55:28 PM »
yes you can build your own, make it a slip joint w/clamp in the center section for easy fitment.
Offline Vagrant
« Reply #6 on: March 21, 2015, 09:56:30 AM »
you will loose a bit of mid range torque and gain a bit of noise under you. you do gain a little bit freer revving in the 4-7000 RPM range. one of the crossovers is better built than the other but I don't remember which.
Bones1300
« Reply #7 on: March 21, 2015, 06:11:04 PM »
Ok great sounds like I can build one. I would like it a little louder anyway lol
« Reply #8 on: March 21, 2015, 07:57:32 PM »
Slip joint- that's what I was trying to say but couldn't think of the word, anyway you can build your own or the easy way is to buy one, cut a section out of the cross and add a slip joint. Clamps from an Ambassador are what I use to secure the joint.
