Author Topic: Recommended wheel balancers?  (Read 8160 times)
Offline tonyduc
    • Staccato Cycle
« on: March 21, 2015, 07:07:05 AM »
I am looking for a quality wheel balancer that is versatile to do both double sided and single sided swingarms (such as what Guzzi CARC bikes would need). Tachyon sells kits which have adapters for both:http://www.webbikeworld.com/motorcycle-wheels/balancer/tachyon-wheel-tire-balancer/. Any recommendations?
2011 Stelvio -white
1976 T3
1996 Ducati 900ss CR
2017 Yamaha XT250
1966 Ford Bronco
Former
1969 Ducati 450 SCR
1984 California II
07 Honda VFR
71 CL350
08 Ducati 848
05 Ducati M620
80 Yamaha XS650
73 Suzuki TC100
Offline Perazzimx14
Re: Recommended wheel balancers?
« Reply #1 on: March 21, 2015, 07:38:01 AM »
Or just throw in some balance beads and be done with it. 2 Ounces in the front and 1 ounce in the rear. No more ugly wheel weights to look at.
I have changed about 80 tires for friends and mostly from an add I put on CL over the last two years. I have used exclusively Counteract Teflon coated balance beads and have not had one complaint. In fact when I get a repeat customer I keep their old balance beads for my tires and give them new ones.
If you insist on buying a static balance I suggest you get the least costly one you can fine that matches your needs. HF sell one and they also have a different cone that works on some single sided swing arm type that works just as well as something priced 5x as much/ It isn't rocket science. Its an axle, two wheel cones, rollers and a support frame.
At or even well above legal road speed a tire that is even remotely balanced will be smooth.
« Last Edit: March 21, 2015, 07:42:12 AM by Perazzimx14 »
Offline pyoungbl
« Reply #2 on: March 21, 2015, 08:08:50 AM »
Although I use a balancer from No-Mar (http://www.nomartirechanger.com/product_p/bl-standard.htm) there are lots of very similar, and less expansive, options.  They all rely on ultra low friction bearings, a very smooth axle shaft, and some kind of cones to adapt to your wheel.
No-Mar offers a wide range of delrin cones but I ended up turning my own adapters for both the Stelvio and V7.  The supplied cones were OK for the Stelvio (single side swing arm, large tapered hole in the wheel) but the one I made is less fiddly.  The V7 axle hole was too small for the cones I had so I made a sleeve to fit the .500" axle and the .640" wheel hole.  This was no big deal and allowed me to play with my lathe.
This same balancer has worked on my ST2, Multistrada, G650GS, R75/6, Norge, and a few friend's bikes.  The key is getting the cones you need for your application, no matter what brand balancer you get...or if you make your own stand.  As for the difference between single side swingarm and a traditional swingarm, that's really a matter of the size of the hole in the wheel.
Peter Y.
'13 V7 Special (red/white)
Offline wrbix
« Reply #3 on: March 21, 2015, 08:42:36 AM »
I've used Marc Parnes wheel balancer on older MGs and BMWs and newer single swing arm BMW for years, quality tool.
Don't bother w a fancy stand just put jack stands on your work bench.
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline Caffeineo
  • Guzzi B00b
« Reply #4 on: March 21, 2015, 09:15:56 AM »
I use Ride-on http://www.ride-on.com/ in the tires on my Bassa. Took off the old lead weights and it works great.  ;-T
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Online RinkRat II
  • Lake Powell AZ
« Reply #5 on: March 21, 2015, 09:33:25 AM »
 Greetings tonyduc, I bought one similar to this and built my own stand http://www.ebay.com/itm/331505281879?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Balanced BMW single side wheels,KLR Guzzi and Honda without a problem
. Look to Ebay for your weights. Pays for itself first time you use it! :bike
    Paul B :BEER:
« Last Edit: March 21, 2015, 09:45:02 AM by RinkRat II »
Offline clubman
« Reply #6 on: March 21, 2015, 09:45:09 AM »
:+1 Works on my Triumph and V7C with no special adaptors.
Offline Cage Free
« Reply #7 on: March 21, 2015, 09:50:55 AM »
The HF balancer works great on my Stelvio's wheels.  No adapter needed for rear. I saw no need to spend big bucks on very basic tool, (sorry MP) Ive done my Stelvio and Griso's wheels and never had any issues with vibration or tire wear.
Offline lucian
« Reply #8 on: March 21, 2015, 01:26:03 PM »
I also use a Mark Parnes static balancer and like it. Precision made with dual ball bearings, just specify which bikes you plan to use it on and they will supply the proper cones with the unit. A couple jack stands or saw horses are all you need to prop it up. Have never tried the beads, but I have heard they can get stuck in the valve stem if you not careful.
