Author Topic: locate lights relay 1993 california 111  (Read 4409 times)
Offline jeffrey1212
« on: March 21, 2015, 07:31:01 AM »
on left hand side under cover i have
1 horn relay
2 starter relay
3 side stand relay
4 flasher unit
all in a row
on the other side is the relay to the digiplex and coils
were is the relay for the lights ?
thanks in advance Jeffrey
1952 AJS 18
1959 Matchless G12 650
1963 AJS 14 CSR 250
1963 Lamberetta LI 150
2013 California 1400 touring
2009 Vespa GTV 250
Re: locate lights relay 1993 california 111
« Reply #1 on: March 21, 2015, 08:59:53 AM »
since no one else has the answer... Are you sure it has a HL relay?
Offline jeffrey1212
« Reply #2 on: March 21, 2015, 09:18:18 AM »
i am not sure but it shows one on the wiring diagram ?
1952 AJS 18
1963 AJS 14 CSR 250
2009 Vespa GTV 250
Online Wayne Orwig
« Reply #3 on: March 21, 2015, 09:18:34 AM »
1 horn relay
2 starter relay
3 side stand relay
4 flasher unit
all in a row
On the 1994, and other newer models, the headlights had two relay contacts to pass through.....
One contact was the back side of the starter relay. It was prone to early failure as it wasn't rated for as high a current and other reasons. So if you have a headlight problem you may want to check that relay. IF is is anything like the 1994s.
