Author Topic: Harpers Outsider Oil Filter Coupling  (Read 3206 times)
Offline Luxexterior
« on: March 29, 2015, 11:01:08 AM »
I'm not sure how I managed to do it but I have stripped the thread of the oil filter coupling on my Harpers Outsider thats fitted to my 1000SP. Does anyone know if the standard Guzzi oil filter coupling (in the sump) is the same fitting or is a suitable replacement for Harpers coupling?
Thanks in advance. ;-T
Offline Dick
Re: Harpers Outsider Oil Filter Coupling
« Reply #1 on: March 29, 2015, 11:22:00 AM »
I don't have the answer for you, but I bet Harper's does. They probably have the piece you need. Good luck.
Offline Luxexterior
« Reply #2 on: March 29, 2015, 11:27:31 AM »
Thanks for that. I've sent an email to the shop & am awaiting for a reply, I realize its Sunday & I may not hear anything for a while.
« Last Edit: March 29, 2015, 11:28:06 AM by Luxexterior »
Offline Luxexterior
« Reply #3 on: June 03, 2015, 12:56:17 PM »
It turned out to be an impossible task to find the type of connector required for the Outsider in the UK. The best I could find was shorter & had a much bigger bore which led to a weeping leak from the oil filter.
Fortunately Curtis Harper came to the rescue & found me the right part from Harper's old stock. Fantastic service, I can't recommend guys these enough. If I was on the other side of the pond I would use Harpers for all my Guzzi needs. Thanks again Curtis :thumb:.
« Last Edit: June 03, 2015, 12:57:28 PM by Luxexterior »
