Author Topic: moly, is it really needed  (Read 19398 times)
Online RinkRat II
  • Lake Powell AZ
Re: moly, is it really needed
« Reply #30 on: March 30, 2015, 10:42:13 PM »
I once sat down on a full open tube of high temp anti seize with predictable results  ::)
   Oh Dusty,your such a tease....now they tell me Clarified Butter . Decisions Decisions........
     PaulB :BEER: :BEER:
Offline krglorioso
« Reply #31 on: March 30, 2015, 10:50:33 PM »
You slippery devil, you.
Ralph
Ralph
2004 Moto Guzzi Breva 750
2017 Honda CB-500F
Morizzi
« Reply #32 on: March 30, 2015, 11:40:14 PM »
Need/needed is a funny term. No lubricant is needed in an engine. It will run for maybe a minute without any and for years with the cheapest oil you can buy. It all depends on what sort of life you are hoping for.
I've written about moly before but I'll do it again.  :BEER:
Friction results in heat. If the rear drive runs cooler with it than without then there is less friction. Simple!  ;-T
I use mineral oil in all of mine and the rear drives run cooler with moly or its equivalent tungsten disulphide. I can measure the difference with an IR thermometer.
Give it a try. Go on. let's be scientific.  :BEER:
Rod in Oz.
Offline youcanrunnaked
« Reply #33 on: March 31, 2015, 07:10:58 AM »
And interesting enough, although my owner's manual says to use molykote the Technical Data Sheet I linked above from Moto Guzzi Service does not even for the models going back to the early '90s.
Tech Note 010-2006 (re: Lubricants) also says nothing about adding moly to the "gearbox"  ::) of any of the models listed, including my hydro EV, even though my MOM says to add it.  So does the Tech Note supersede the manual, or did those crazy Italians simply overlook their own specifications?  In this case I choose to go with the advice I got in the MSF BRC:  "Always listen to your MOM."  It's not that much of a burden to add a shot of moly, and it can't possibly hurt.
Also, since I am using the same gear oil in the transmission and the rear diff, I choose a mineral oil.  Maybe it will help keep that plastic bearing cage in the transmission intact, maybe it won't.   :-\
« Last Edit: March 31, 2015, 07:20:00 AM by youcanrunnaked »
Offline Two Checks
« Reply #34 on: March 31, 2015, 07:19:48 AM »
Amazingv how a final drive became a transmission.
It's a modern miracle!  :bow
1987 1000 SPII "Il Duce' II"
Offline sib
« Reply #35 on: March 31, 2015, 07:46:59 AM »
Well, it DOES transmit power from the gearbox to the wheel.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Rough Edge racing
« Reply #36 on: March 31, 2015, 08:10:33 AM »
Rod in Oz.
 Have you made comparisons with different brand oils or synthetics without the moly additive?
« Last Edit: March 31, 2015, 08:11:11 AM by Rough Edge racing »
Offline Tobit
« Reply #37 on: March 31, 2015, 08:21:21 AM »
Oh by bike:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB8QFjAA&url=http%3A%2F%2Fwww.harpermoto.com%2Fpm65%2FTechnical%2520Data%2520Sheet.pdf&ei=XZkZVbbJHK3IsATEhYCAAg&usg=AFQjCNEe3m9M23wA2OM3SJJatI40hZWucw&sig2=VB50EMPSO37o-UUm3KiQcA&bvm=bv.89381419,d.cWc&cad=rja
That's useful!  Saved to my library, thanks!  Now if I can plot it out on a 24"x36" sheet, it will hang in the garage.
Interesting, "gearbox" and "transmission" refer to transmission and final drive.  What's in a name?
Tobit
Roman, '86 LM IV
« Reply #38 on: March 31, 2015, 08:24:46 AM »
Except MG is not even consistent in their translations.  In that 2006 Tech Note, "transmission" is transmission, and "gearbox" is rear differential.    :o
« Last Edit: March 31, 2015, 08:26:00 AM by youcanrunnaked »
« Reply #39 on: March 31, 2015, 08:37:18 AM »
Ok,  What to call it?  Transmission? Gearbox?  Bevel box?  Final drive?  Not-a-CARC?  I give up.   :P
« Last Edit: March 31, 2015, 08:37:46 AM by youcanrunnaked »
« Reply #40 on: March 31, 2015, 07:43:01 PM »
Except that the guzzi does not use a differential on account of there is only one rear wheel -- nothing to differentiate.
« Reply #41 on: March 31, 2015, 07:53:32 PM »
rear end
Offline rbond
« Reply #42 on: April 01, 2015, 02:44:24 PM »
So it is a definite yes and no? I think the component in question is scientifically called a '90 degree rotational redirecting, reduction, bevel geared, energy transmitting, all metal, in an oil bath mechanical device'. Thanks for everyone in clearing up / muddying the water advice. You guys are hilarious!!! Even if nothing concrete is decided on, it is very entertaining.  :pop
2012 MG V7C
1976 Suzuki GT500A
1978 Suzuki GS400C (long gone)
1973 Suzuki TS 100K (first new bike)
1969 Honda S90 (very first bike)
Offline sib
« Reply #43 on: April 01, 2015, 05:24:39 PM »
Indifferential.
