Author Topic: Any downside to this other than effort and money?  (Read 4770 times)
« on: April 01, 2015, 02:14:57 PM »
Derale 13011 Fluid Control Thermostat Kit
http://derale.com/products/fluid-coolers/thermostats-1/fluid-control-thermostats
For a Norge 2013.
Probably not needed but you know how these things go.
Re: Any downside to this other than effort and money?
« Reply #1 on: April 01, 2015, 02:34:31 PM »
It seems like a reasonable solution to overcooling, if your engine has trouble with that.  I take it there isn't any flow control to the oil cooler from the Guzzi factory.  (?)
Offline pyoungbl
« Reply #2 on: April 01, 2015, 03:11:18 PM »
I too have been thinking about this solution to the overcooling problem which is worse on the Stelvio NTX due to the huge oil radiator.  When I ride in the rain the engine cools so much that the ECU shoots more fuel into the engine and my mileage goes to 30 mpg or so.  On a cool day the engine seems to take forever to warm up and probably never does get up to full operating temp.  It will be interesting to see how you add this to your Norge.
Peter Y.
'13 V7 Special (red/white)
« Reply #3 on: April 01, 2015, 03:17:51 PM »
Here is another possibility. http://www.jagg.com/by-pass.html
TOYS:
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper,
1988 Mercedes 560SL
« Reply #4 on: April 01, 2015, 06:58:11 PM »
The P/N 4050 looks good to me. Cheap. Many aircraft oil cooler thermostats work the same way.
« Reply #5 on: April 01, 2015, 11:54:57 PM »
Going to give it a try. I'll reports results.
