Author Topic: Norge front fork adjustment  (Read 8412 times)
kris
« on: April 05, 2015, 04:09:00 PM »
I hope someone can enlighten me, I've searched the internets and the manual isn't very clear on how to adjust the front fork.  It says to open the adjuster all the way then close it three turns.  I'm assuming opening is backing it out and closing is tightening?(they were all the way tightened).  Also, when I went to loosen it seems like I'm loosening the fork cap, not the adjuster inside. Is this how it's supposed to be?  It does come to a stop but to me it looks like the smaller bolt with +& - marks should turn inside the larger nut.  Any help would be appreciated, thanks, Kris
Offline Waltr
    • Europa Macchina
Re: Norge front fork adjustment
« Reply #1 on: April 05, 2015, 04:20:32 PM »
  The larger nut should be secured in the fork. Tighten it but 8-9 ft lbs and not much more.  It seems this is common and using a little silicone lube at the base of the 17mm adjuster in the center of the fork cap bolt will allow the two to work independently.  All the way soft (or loose) is with the 17mm bolt fully counter clockwise.
www.motoguzzipa.com
2012 Norge
kris
« Reply #2 on: April 05, 2015, 04:28:03 PM »
Thanks for your answer.  I thought it was that way.  Must have beeb cranked tight from the factory.  Now I need to find the right size socket so I can torque down the fork cap.  Any idea what size it is?
Thanks again :bow
56Pan
« Reply #3 on: April 05, 2015, 06:26:52 PM »
Just checked mine.  It's 30mm.
Offline frans belgium
« Reply #4 on: April 06, 2015, 02:05:16 PM »
Make sure the larger bolts are tight
The smaller nuts settings depend on your personal preference.
I would say anything between completely loose +3 up to completely tight - 3 turns.
As for me, I wasn't happy with any of those and went from 15 grade front fork oil to 10, which made a world of difference.
But to each his own....
« Last Edit: April 06, 2015, 02:05:51 PM by frans belgium »
Owned and sold: V65, Nevada, 2xCali, Breva 1100, Norge 8V, Breva 1100 with Squire sidecar
Currently own: V85 TT
kris
« Reply #5 on: April 06, 2015, 04:52:49 PM »
Thanks.  I have a socket that fits, but I have to remove the handlebars to get the socket on the nut as there's not enough clearance.  Maybe I'll look for a thin wall socket?
kris
« Reply #6 on: April 06, 2015, 04:53:45 PM »
I'm assuming this softened the ride up a bit?
Offline Trialsman
« Reply #7 on: April 06, 2015, 06:12:20 PM »
How many cc of the 10 wt do you use in each leg?  I was also looking for a way to reduce the compression damping and this might do the trick.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2025 Arctic Leopard Ex-800
Offline MLR
« Reply #8 on: April 07, 2015, 07:00:36 PM »
I went with 10W Maxima 110mm from the top of the tube with the fork compressed & springs & plastic tubes out(this is factory spec). I like it, not dramatically softer but it seems to take stutter bumps better.
Offline Trialsman
« Reply #9 on: April 07, 2015, 10:11:08 PM »
Thanks - I will give it a try.
2010 FE570 Husaberg
2024 Stelvio V100
« Reply #10 on: April 09, 2015, 01:42:59 AM »
yep!
« Reply #11 on: April 09, 2015, 01:48:26 AM »
The front suspension was way too harsh for me on sudden bumps. No setting could cure this.  So I went on to Progressive springs, hoping this would settle the matter. It didn't.  Though it took away some of the harshness, I still wasn't satisfied.  Then I went to 10W on the new springs, and everything fell in it's place.  So now I still wonder if the new springs were really needed.  So if the front suspension bothers you, start with 10W instead of 15 and see what happens.  You can still move to progressive springs afterwards, if needed.
« Last Edit: April 09, 2015, 01:49:11 AM by frans belgium »
