Author Topic: Has anyone ever heard of an inertial kick start mechanism?  (Read 11065 times)
Doppelgaenger
« on: April 11, 2015, 10:19:17 AM »
So I was talking to a coworker last night, he mentioned that he has ridden a bike where he had to kick start an inertial flywheel system before starting the bike.
Has this ever existed? The only place I've ever seen an inertial starter is on radial aircraft engines. This guy is notorious for being a compulsive liar...
Online RinkRat II
  • Lake Powell AZ
Re: Has anyone ever heard of an inertial kick start mechanism?
« Reply #1 on: April 11, 2015, 10:41:27 AM »
 ??? Wasn't  that how the early mopeds were started? Pedal to get the flywheel going and then the engine took over,  :pop
    Paul :BEER:
« Reply #2 on: April 11, 2015, 10:51:07 AM »
    Paul :BEER:
The ones I remember used the pedals to get the bike moving.  Then you engaged a clutch to get the engine spinning to start it.
« Reply #3 on: April 11, 2015, 12:54:02 PM »
Closest thing I've seen is a video of a guy (in flip-flops no less) kickstarting a Guzzi Falcone. He uses the kickstart lever to rock the (external) flywheel back and forth until enertia finally takes over and it starts.
« Reply #4 on: April 11, 2015, 01:55:11 PM »
« Reply #5 on: April 11, 2015, 02:12:49 PM »
Has to better than a pull start. I hate those.
 :P
Offline Doug McLaren
« Reply #6 on: April 11, 2015, 02:39:28 PM »
What about a kick-start car ?
https://www.youtube.com/watch?v=2UMeA6jl1Uk
2019 V85TT
1994 Ducati 900 Monster
1957 Lodola 175
« Reply #7 on: April 11, 2015, 03:04:44 PM »
 The last sentence of the original post tells the answer to the question.
« Reply #8 on: April 11, 2015, 03:07:52 PM »
25hp, 36hp and bastard VW engines as well as my '50s triumph cars had lugs on their pulley bolts for a hand crank start.  My triumph cars and some of our farm tractors also had rope pull options.  My 'modern' Honda 90hp marine engine also has a rope start shiv around the flywheel for in case the starter doesn't work.  Like I'm gonna rope start a 90hp 4cyl outboard . . .
Offline garbln
« Reply #9 on: April 11, 2015, 03:23:56 PM »
I saw a small 50cc dirt or trials bike, Honda I think that had a sort of inertia starter on it a couple of years ago.  You put the bike in neutral, pulled the clutch in, kicked the starter, and let the clutch out.  It was a very small bike for maybe a 5-10 year old.  It was a 60's or 70's model I think.  I think I have a picture somewhere if I find it I'll try to post.
Offline SED
« Reply #10 on: April 11, 2015, 05:43:09 PM »
The Ariel owner's guide suggests getting the flywheels in motion and then giving it compression - essentially the same thing?  :pop
I posted it all just so you'd know how to do it...  ;D
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
« Reply #11 on: April 11, 2015, 05:49:36 PM »
I like the dipper switch. ;D
Offline Mike Harper
    • harpermoto.com
« Reply #12 on: April 11, 2015, 06:10:01 PM »
Honda Express Moped
You push the lever repeatedly until the spring is wound tight and you pull the trigger
Offline redrider90
« Reply #13 on: April 11, 2015, 07:25:16 PM »
How else would one start a weed eater engine . Hmm , what about a kickstart lawnmower  ;D
The one has its own inertia for sure. Fires you right up just looking at it.  ;D :P
Red 90 Mille GT
« Reply #14 on: April 11, 2015, 08:31:03 PM »
That was from back in the day when you were expected to know what made a motor run. <shrug> Now, all you are expected to know is how to turn on the key and punch the button. If nothing happens? Oh, never mind...
Personally, I just call WG.  ;D
Doppelgaenger
« Reply #15 on: April 11, 2015, 10:05:26 PM »
Can you imagine the smell that thing puts out?
« Reply #16 on: April 12, 2015, 05:12:11 AM »
That looks like my model VB it had the same dash in tank
600cc sidevalve single, great old bike 1948 if my remembery is working.
Offline Murray
« Reply #17 on: April 12, 2015, 08:42:51 AM »
I have a vague recollection of someone doing it at an old bike show however can't recall what bike it was on. A lot of the early machines the pedals drove the rear wheel and to start you pedalled the rear wheel into action while on a stand to start the motor so a form of inertial starting.
Offline SED
« Reply #18 on: April 12, 2015, 08:50:42 AM »
Should be the same except maybe tele forks on a '48.  Owner's Guide is for all the Ariel singles 1939-1947.  The bikes didn't change much year to year.  The VB is a cool bike, but I'd bet your Guzzi is more usable.  ;D
1983 LeMans III
1981 Monza
1937 Guzzi GTV
