Author Topic: G&G deep sump install  (Read 9065 times)
Offline oranges3
  • "this amp goes to eleven..." Nigel Tufnel, Spinal Tap
« on: April 13, 2015, 07:09:47 AM »
i have installed a G&G deep sump on my 2003 EVT...
there is a hole on the rear side that looks like it is for a drain plug...
the actual drain plug is on the bottom.
the kit did not come with anything to plug this hole nor by the pics is it supposed to...
anybody got any ideas?
the hole is visible on the MGCYCLE website for this product.
Any and all help is appreciated:)
2012 ducati diavel
1995 Triumph Speed Triple
1998 Triumph Thunderbird Sport
2004 V11 Cafe Sport
1999 Confederate America GT
2018 Motus MST
2007 griso
1986 kawasaki ninja 600r
183 Honda VT500 Ascot (son's bike)
Offline twhitaker
Re: G&G deep sump install
« Reply #1 on: April 13, 2015, 08:21:48 AM »
It looks to me like that is a construction hole and needs to be plugged. Most likely, Gordon can get you the proper plug.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline mtiberio
    • TiberioRacing
« Reply #2 on: April 13, 2015, 09:14:17 AM »
is it for an oil filter feed?
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
190 Octane
« Reply #3 on: April 13, 2015, 11:15:41 AM »
I just installed one from MG cycle as well.  The only hole not filled on mine was the drain hole on the bottom.
Offline oranges3
« Reply #4 on: April 13, 2015, 12:02:20 PM »
See the hole... nothing in the kit to pug it up.
http://www.mgcycle.com/images/atrex/mg368_04.jpg
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
190 Octane
« Reply #5 on: April 13, 2015, 12:55:37 PM »
Will the drain plug from your original sump fit?  It looks to be in the same spot.
Offline TOMB
« Reply #6 on: April 13, 2015, 02:55:45 PM »
Maybe  you  can  fit a temp Guage for oil. Problem  solved
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #7 on: April 13, 2015, 04:25:53 PM »
Condensate return as used on later models/Spineys?
Offline pressureangle
« Reply #8 on: April 13, 2015, 07:43:55 PM »
My G&G is still sitting on the bench, came with plug installed. Check your package to see if it fell out, or came separated?
Offline oranges3
« Reply #9 on: April 13, 2015, 07:47:49 PM »
Gordon at mgcycle is getting me the plug...
Mine did not come with one installed.
Can't ride the bike until then.
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
Offline Mike Harper
    • harpermoto.com
« Reply #10 on: April 14, 2015, 09:18:17 AM »
Why does he not send you a new one that is complete instead of making you wait till something comes from someone else.
Offline oranges3
« Reply #11 on: April 14, 2015, 04:53:53 PM »
Out of stock... would
be nice though
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
Offline Mike Harper
    • harpermoto.com
« Reply #12 on: April 14, 2015, 05:17:52 PM »
For that situation on our products we would offer what we refer to as a "return authorization" and we send a UPS call tag.  Which is quickly followed up after we received the item back by a full refund including the original shipping cost.
But , That is just the way we are ;-T
Offline guzzista
« Reply #13 on: April 14, 2015, 09:10:17 PM »
You guys have come a long way from the old days. Back in the late 1980's I ordered a pair of dogleg levers for my CX, got sent either 2 lefts or 2 rights , don' t remember which anymore , but when I called I suggested that I would just order another pair for my other bike, but 2  lefts or rights instead of a correct pair, and I was told that I would  have to first return the 2 I received or nothing else could be done. The bad taste of that transaction  remained in my memory since then.
« Reply #14 on: April 15, 2015, 07:23:48 PM »
He only needs to wait if he wants to.  He could run down to the parts house and get the plug and washer for a couple of bux, or he could just keep the spacer on the shelf until the part is delivered and install it at that time.
I like the design.  It does away with the extra parts needed on some of these conversions, and it hides the filter in a well where it's both accessible and well protected.
Offline oranges3
« Reply #15 on: April 17, 2015, 06:40:21 AM »
New sump on the way!!
Return authorization number to follow for the sump missing plug.
Should have it by Monday...
Stay tuned.
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
Offline Mike Harper
    • harpermoto.com
« Reply #16 on: April 17, 2015, 12:53:34 PM »
Stay tuned.
That is the way the world should work ;-T
Customer should never have to repair the new part he just paid for.
