Author Topic: Cheap blind bearing pullers  (Read 7082 times)
« on: April 15, 2015, 05:08:22 PM »
I bought a set of blind bearing pullers off Ebay from China, arrived today,
The whole set including shipping was $32.76 ;D
Cheap at twice the price for the limited use they will get, I have the slide hammer type but these are so much easier on the soft alloy of a transmission case and you can slowly wind out the bearing rather than using the reverse hammer action of a slide puller. I may weld the 'washers' to the ends of the open tubes and it would be very easy to make up different tubes sizes for various bearing diameters.
http://www.ebay.com/itm/201197116887?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Individual Guzzi blind bearing pullers for transmissions, when rarely available have bid up over $100 a piece.
Worth the risk for my money :BEER:
Re: Cheap blind bearing pullers
« Reply #1 on: April 15, 2015, 05:33:33 PM »
Thanks for the tip, let us know how they work (how well they're heat treated  ;) ). What's the inner diameter of the two tubes?
I had a very stubborn bearing in a 4 spd. recently and whipped up this contraption to extract it. Did the job, just isn't very "pretty".
« Last Edit: April 15, 2015, 05:35:54 PM by Antietam Classic Cycle »
« Reply #2 on: April 15, 2015, 05:40:07 PM »
35mm and 28mm
I am going to tear into my 750 S3 transmission on the weekend and will see if these tubes work or if I need to make up custom ID pipes to suite the various case bearings.
Jim
« Reply #3 on: April 15, 2015, 06:48:22 PM »
35mm and 28mm
Jim
The ball bearings of a 5 spd. are 47 and 52 mm o.d., the needle bearings are 35 mm.
Offline ken farr
« Reply #4 on: April 15, 2015, 09:32:52 PM »
...good ole Merican NPT plumbing fixtures to the rescue!!!....
   ( that's a sign of a good shop, and mechanictition )
« Last Edit: April 15, 2015, 11:22:24 PM by ken farr »
ken farr
06 B1100 - click!
Fillmore, Ca.
Offline dl.allen
« Reply #5 on: April 15, 2015, 10:19:17 PM »
harbor freight has the cheap blind bearing puller sets.  I think I paid about 40
Offline Phang
« Reply #6 on: April 16, 2015, 05:42:03 AM »
can't resist to translate the words on the box, from top to bottom, it goes:-  ;D
Original quality
Motorcycle specific maintenance tools
High quality
bearing puller assemblies
2000 V11 Sport (Green)
1973 V7 Sport (Green)
« Reply #7 on: April 16, 2015, 10:40:29 AM »
Yes, but they don't come with the tubes/cups, only a slide hammer. My blind bearing puller set is an OTC brand and is very nice, worth the $80 I paid for it. But sometimes you need the tubes to make the job easier. In the photo of my bearing puller contraption, you'll see one of the collets from the OTC set.
Offline Groover
    • Scooteropolis
« Reply #8 on: April 16, 2015, 12:55:42 PM »
Thanks for posting. I ended up renting a hefty set from Autozone. It's a tool rental program and you basically you pay for it and if you break it you buy it and if not, then you return it and get your deposit back so it's basically free rental. It's not a use it and return it like "oh I didn't like it type thing", it's just their standard tool loan program. As long as I don't lose my receipt and don't break I should be good.. and... where is that receipt now... ???
Though for the price of the one you just bought and it has free shipping, it's seems worth buying it for sure. Definitely report back with the quality, and also, how long did it take for delivery?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #9 on: April 16, 2015, 05:50:52 PM »
Prompted me to look on AliExpress.  Some of the stuff they sell is freight included to NZ.  Bought a few things for the lathe simply because at the time no one here seemed to stock what I wanted. ::) However, all their blind bearing pullers have freight as an extra, and that is some extra! :o :o
So far I most of the blind stuff have been wheel bearings so I just run the arc welder around the inside of the cup and it falls out.
That looks a good useful set for the $ Canuck, cheaper than some of the freight charges that I saw.
Offline dl.allen
« Reply #10 on: April 16, 2015, 10:30:24 PM »
here is mine.  Little more than I paid but works great
http://www.harborfreight.com/blind-hole-bearing-puller-95987.html
