Author Topic: Loose Fuses  (Read 13397 times)
Re: Loose Fuses
« Reply #30 on: April 21, 2015, 10:00:36 PM »
Either fuse will kill the pump, I'm a little concerned that one would blow, it just feeds the ECU.
I haven't been able to find a good schematic for my 98 with the P8 ECU, they all show the 15M
Don't worry about the fuse holders flopping around, they all do it but check and make sure each fuse is gripped securely by the base contacts.
didn't blow any fuse.  they just came loose.  I replaced them all with new ones after I used contact cleaner.
Re: Loose Fuses
« Reply #31 on: April 21, 2015, 10:47:28 PM »
Sorry I jumped to conclusions
I couldn't figure out how it could blow without there being a problem with the ECU
