Author Topic: Blind puller for CARC swingarm bearings  (Read 5110 times)
Offline pyoungbl
« on: April 27, 2015, 09:03:06 PM »
In anticipation of replacing the swingarm bearings in my Stelvio I am going to need a tool to pull the bearing races.  The ID of the race is 37.5mm so you'd think a 37mm puller would work.  The swingarm has two reliefs that look like they are designed for something like a regular bearing puller...nothing I have found seems to work.  I tried a MotionPro 35mm blind puller and it's too small.  What are others using?
When I greased the bearings, some 15,000 miles ago, there were a couple rust looking marks on the race.  The race felt OK so I slapped it all back together with lots of grease and called it good.  The next time I go in I want to be prepared for the worst and, to that end, I already have replacement bearings.  Any suggestions?
Pete, I don't have a Dremel tool to cut the race out.
Peter Y.
'13 V7 Special (red/white)
Re: Blind puller for CARC swingarm bearings
« Reply #1 on: April 28, 2015, 02:35:41 AM »
Sorry, I've been really busy today. I have a few suggestions but I'll post 'em up later.
Offline leafman60
« Reply #2 on: April 28, 2015, 06:47:53 AM »
These sweet little things-
Are you in some sadistic mood to inflict pain upon yourself? lol
I hope you're not planning on attacking this before this weekend's rally!
Also, I cannot believe a master machinist with an expensive milling machine does not have a homely little Dremel tool! If you wanna use mine, let me know and I'll bring it to Hiawassee (as long as we don't attempt the bearing replacement at the campground).
« Last Edit: April 28, 2015, 06:51:15 AM by leafman60 »
Offline lucian
« Reply #3 on: April 28, 2015, 08:39:48 AM »
I would think heating the cast housing and then tapping the race out with a brass drift working around it's circumference would work.
breva1200
« Reply #4 on: April 30, 2015, 04:10:22 AM »
DREMEL !  ;-T
I used the small grinding tool for my bearings. Be carefull not to grind in the housing or at least not to much.
Offline boatdetective
« Reply #5 on: April 30, 2015, 06:14:43 AM »
An old mercruiser trick is to fire up a welder and buzz a zigzag pattern around the face of the race. the distortion should help it to pop out.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
Offline JoeW
    • The Guzzi Doctor
« Reply #6 on: April 30, 2015, 08:01:30 AM »
.  :+1
I use my small MIG welder and run a bead around the inside surface of the race. Once it cools, the race shrinks and you can get them out with a lady finger prybar or a small slide hammer with inside jaws or a hook.
Joe Walano
