Author Topic: Mystery no-start on Breva 1100 (again)  (Read 16788 times)
Re: Mystery no-start on Breva 1100 (again)
« Reply #30 on: November 13, 2018, 06:31:53 PM »
I've not taken one apart but it's like a bearing in a shallow pocket. As long as it's horizontal after it rattles it should work. So, if it doesn't work and you rattle it then set it horizontal, it should work again. If you hear no rattle it's stuck on or off.
On the G it's in w/relays, twice the size and square rubber mounted.
Most likely looks like this and not a ball in socket
https://www.youtube.com/watch?v=A2A9rN7EYYY&feature=youtu.be
« Last Edit: November 13, 2018, 07:19:49 PM by guzzisteve »
« Reply #31 on: November 13, 2018, 09:26:15 PM »
Thanks Steve, I now know what to look for, I can see how it might stick in the tipover position.
It disables the starter, when I hot-wired the starter it must have shaken free.
Offline sanchin10
    • http://wildguzzi.com/forum/index.php
« Reply #32 on: November 14, 2018, 09:58:51 AM »
Thank you to Kiwi Roy & Guzzi Steve for your indisputable Guzzi knowledge/feedback! It's cold and windy 31 degrees here this morning and as soon as it warms-up a bit, I'll check out the relay & set it horizontal after the rattle. Hopefully, that's the problem. Is the starter button assembly#3 relay as it may need be replaced. I'm pretty sure that the starter button assembly will need to be replaced & wondering if there any aftermarket assemblies that are interchangeable?
Will give you Guzzi wizards feedback subsequent to applying your advice.
Thanks again!
sanchin10
« Reply #33 on: November 14, 2018, 10:59:46 AM »
For the switch, check w/Pinwell, used electric stuff moves slow.
« Reply #34 on: November 14, 2018, 03:08:03 PM »
Here is the schematic for your Breva 1100
http://www.thisoldtractor.com/guzzi007/schematics/2005_Breva_1100.gif
I was looking at the Kill switch to see if I could follow your description and I notice something might be useful.
The Number plate light is wired from the switch, check it is on when  the key is on ready to start.
The light should be fully on indicating that you have 12 Volts on the yellow wire
The light should remain on when you press the start button, if it goes out that proves you are getting too much Voltage drop through the switch.
Most Breva owners will recognize where this is leading.
« Last Edit: November 14, 2018, 03:34:23 PM by Kiwi_Roy »
Offline hannibal smith
« Reply #35 on: November 15, 2018, 12:25:20 PM »
I posted a similar issue last year on my 2009 V7. Just another possibility.
It turned out to be a faulty (cold) solder on the ignition switch. It was literally hanging on by a thread, and would permit contact for conductivity every once in a while.
I just ended up re-soldering the connection. Been great since.
