Author Topic: CalVin linked brake system weirdness  (Read 3006 times)
Offline lazlokovacs
« on: May 06, 2015, 11:47:08 AM »
Seems like every 18 months or so my CalVin loses pressure in the linked (foot-controlled) brake system. The pedal goes all the way to the floor applying very little braking force. Each time, I've bled the brakes and checked for leaks and all has been well. For about 18 months. Then it just happens again. I'm on the third cycle of this now. Not like a gradual lessening of pressure, it just.... happens..
The complexities of the linked brake system obviously mean that there are more places for the system to fail... I can't see any leaks, have snugged up all the bleed nipples with teflon as well..
As ever,  any ideas?
Offline ibis1
Re: CalVin linked brake system weirdness
« Reply #1 on: May 06, 2015, 12:38:01 PM »
If your not losing fluid, it's most likely the rear master cylinder. Do you get any air out when you bleed it?  :BEER:
2010 California Vintage (Gone)
1971 750 Ambassador (Gone)
2014 California Touring
Online Wayne Orwig
« Reply #2 on: May 06, 2015, 12:49:21 PM »
As mentioned, do you get air? If so where does the air come out?
Is the fluid level dropping?
I doubt it is anything directly related to the 'integrated' brakes.
Offline mtiberio
    • TiberioRacing
« Reply #3 on: May 06, 2015, 01:20:02 PM »
rebuild the rear master cylinder
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #4 on: May 06, 2015, 01:24:37 PM »
Can I pile on?  ;D
