Author Topic: New turn signals, things to look out for.  (Read 4350 times)
Gintonious
« on: May 06, 2015, 04:57:00 PM »
Hey guys,
Changing up the turn signals on my Guzzi LeMans 3, the current ones are beat, literally hanging off, so its time for an upgrade.
Looking at these as they would complement the tank, aluminium casing etc, and the reviews are good also.
There are 2 options on this light, a single filament and a dual filament. Is this something that would affect the operation of the lights, or is it just that one would be brighter than the other?
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-electronic-lighting-parts-mini-rectangle-aluminum-clear-turn-signals-blinkers-25-8305.html
Offline Hahnda
    • Scrambler Cycle
Re: New turn signals, things to look out for.
« Reply #1 on: May 06, 2015, 05:11:19 PM »
Single filament is your basic blinker.
Dual filament allows you to have running lights, you need the wiring to use them though.
1949 GTV - 1948 Airone
www.scramblercycle. com
Gintonious
« Reply #2 on: May 06, 2015, 05:29:00 PM »
Probably a safer bet then going with the single.
Online bad Chad
« Reply #3 on: May 06, 2015, 06:01:19 PM »
Whatever you go with make sure they are large enough and bright enough to be easily seen.
1988 YX600 Radian
Offline kidsmoke
« Reply #4 on: May 06, 2015, 06:22:01 PM »
This.
I just went LED bar end signals. So small and ridiculously hi vis. Great in my urban environment.
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Gintonious
« Reply #5 on: May 06, 2015, 06:30:57 PM »
Reviews of the one above seem favourable, so I will go with a set of them.
Offline Trinorman
« Reply #6 on: May 07, 2015, 01:15:41 AM »
1984 V65SP
Gintonious
« Reply #7 on: May 07, 2015, 01:28:08 PM »
Thank you very much!
