Author Topic: Lemans rear tyre change: hints & tips  (Read 4617 times)
Offline earemike
  • Lurker
« on: May 07, 2015, 05:01:41 AM »
Hi all,
newly arrived LeMans in the shed & I've got a set of Pirelli Sport Demons waiting to go on.
Thought I'd ask for any hints/tips about the rear tyre change. Looks like I can remove the rear caliper & mount similarly to the V11 but better to ask now than have the rear in pieces!
Cheers,
Mike
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Offline Perazzimx14
Re: Lemans rear tyre change: hints & tips
« Reply #1 on: May 07, 2015, 05:36:50 AM »
Hi all,
Cheers,
Mike
Nothing out of the ordinary. Rear wheel off the ground remove the caliper from the bracket, remove the axle, push the wheel to the left to disengage the cush drive fingers and pull back to remove. Thank note of where the spacers are and that's it.
« Reply #2 on: May 07, 2015, 06:49:57 AM »
A piece of wood on the floor will make the lift just a bit higher so the tire will clear the license plate bracket.
Offline mtiberio
    • TiberioRacing
« Reply #3 on: May 07, 2015, 07:01:22 AM »
you don't remove the caliper from the bracket...
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline earemike
  • Lurker
« Reply #4 on: May 07, 2015, 08:51:26 AM »
Thanks all  ;-T
exactly what I was after, good to know the caliper & mount can stay together.
The timber tip is gold, I do this with my V11 to clear the mudguard but wouldn't have thought of it first time round on the LeMans.
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Offline mtiberio
    • TiberioRacing
« Reply #5 on: May 07, 2015, 11:13:10 AM »
you have to have enough slack in the brake line, and you tilt the caliper bracket back and clockwise and make sure its axle spacer part drops into one of the rear rotors cutouts...
Offline Stevex
« Reply #6 on: May 07, 2015, 04:47:41 PM »
Whenever I remove the rear wheel of my LM2 I always remove the brake caliper first.
With that out of the way, the caliper mounting bracket is 10 times easier to remove and refit.
