Author Topic: Valve stem size.  (Read 4179 times)
Offline ken farr
Valve stem size.
« on: May 07, 2015, 10:01:22 AM »
Hello All:
  So this weekend, maybe next, I will be changing the rear tire ( Shinko 009 ) on my 06 B-1100.
  Does anyone know what size the valve stem is ?
  8mm or 10 mm.
  I want to change out the valve stem since I have a slow leak there.
  Thanks in advance.
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Re: Valve stem size.
« Reply #1 on: May 07, 2015, 11:33:15 AM »
I just replaced one on a customer's Norge, but can't remember for sure. I do know it's the same one that Ducati uses on a bunch of their bikes - any with Brembo wheels.
From this photo, I'd say 8 mm. I do remember using a 13 mm socket to tighten the nut, so that points to 8 mm as well.
« Last Edit: May 07, 2015, 11:34:28 AM by Antietam Classic Cycle »
« Reply #2 on: May 07, 2015, 12:51:42 PM »
It's ~8mm.  Depends on where I measure it.
Valve stems are not expensive, but the leak is probably the o-ring, which is even cheaper.
nunzio
« Reply #3 on: May 07, 2015, 02:55:41 PM »
Whew!!!!!
I'm glad I have tubes...one less thing to remember  ;D
Alan
« Reply #4 on: May 07, 2015, 03:07:50 PM »
It's rare to change metal valve stems.  Usually any leak (also unusual) is repaired by changing the valve stem or sealing o-ring.
« Reply #5 on: May 07, 2015, 03:22:42 PM »
The one I had to replace was due to someone somehow stripping the internal threads, so the valve core wouldn't come out. The valve body does seems to be a very soft alloy, but how do you do that?
Offline Bisbonian
  • Living the Dream
« Reply #6 on: May 07, 2015, 10:46:46 PM »
8mm. I just replaced the o-ring on a leaker.
