I wish Moto Guzzi would specify the suspension travel at both ends on these bikes. The next to no travel on the Griso is what finished it off for me. There was no way I could modify it either, due to the design of the swingarm and the mono-shock placement.The Cali14 and family however have shocks on the sides of swingarm, so should be more potential travel.
I am surprised to see the Eldo is only in black. The show version was red and looked so good it is my screen saver. To me it is much better looking in red. YMMV
Fwiw, remember wheelbase has an effect on the perception (harshness) of suspension travel.
The Griso was very restricted even after RT rebuild of OEM shock, did make it better tho. Guess I'm just spoiled from the big ADV bikes, and the 4.4 or so inches of travel on the rear seems very limited.My last cruiser was like, 2007 (99 FXDX), probably not much travel on that bike either, and I don't seem to remember it caused a problem.I'm not so sure the Stelvio has that much travel without actually testing on a lift without the shock, but pretty sure the Griso cannot be made to have more. If the swingarms are the same, then I agree, parts from the Stelvio, either linkage or shock could make a difference. (I was involved with the linkage recall, and think they both had the same part, which to me appeared the only one that would fit in that tight space).Anyway, the suspension travel is a pet peave of mine with all bikes. Guess I am rebelling already on thinking of what I must give up to move to a Cali14 or compatible, Indian. No HD for me tho, knock on wood.
I think some people just set the suspension bar way high. I've ridden the current RK, along with the Cali, Indian, and equivalent Vic offerings and the suspensions were all frickin magic carpet rides compared to a lot of motorcycles.
If you've had a fiddle around with almost any of the high performance suspension from the sports bike side of things or even ridden the results of a decent setup from your local specialist. The expectation is high because we know what can be done. If you are paying top dollar for a product expecting it to be good or at least be able to adjusted to good from the get go is not unreasonable IMO.
I didn't need to push my V7 50 feet to know the stock shocks were horrible.
Agreed. However, for many (as it will depend on rider weight) the stock set-up will launch them right off the seat in way too many situations. This is unacceptable. Two I rode would sent me for air at 40mph.
Suspension adjustments and set-up are not unknown concepts for me. I'm aware. IMO there is not acceptable set-up as delivered stock.As always, YMMV.
I weight more than any motorcycle is specified to carry.
OK, did they steal those side bags off a Victory?
