Author Topic: Italian polarity symbols  (Read 4235 times)
Offline tpeever
« on: May 08, 2015, 02:35:13 PM »
On the face of the Marelli ignition coil on my V700, the right hand side (coil facing right side of bike) is marked "B+" and the other side "D". I assume the former is the positive side and should be connected to the blue/black wire from the fuse panel and the latter is negative and should be connected to the distributor?
2024 Suzuki V-Strom 800
1979 Kawasaki KZ1000 LTD
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1974 Norton Commando
1968 Moto Guzzi V700
1967 Triumph TR6C
1961 Norton Dominator
Re: Italian polarity symbols
« Reply #1 on: May 08, 2015, 02:46:30 PM »
I think that would be a safe assumption.
I would work either way but there is a tiny advantage having it correct, a few hundred extra spark Volts
I have no idea if the attached is true or BS
http://mgaguru.com/mgtech/ignition/ig104.htm
LaMojo has the best answer so far  ;-T
I can verify that, I grew up with steam radio.
« Last Edit: May 08, 2015, 04:58:01 PM by Kiwi_Roy »
Offline mtiberio
    • TiberioRacing
« Reply #3 on: May 08, 2015, 04:00:49 PM »
Digital ohmeter?
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
LaMojo
« Reply #4 on: May 08, 2015, 04:26:52 PM »
B+ is used on almost all electronic schematic diagrams beginning early in the tube era. Means Battery Positive supplying a circuit.
« Last Edit: May 08, 2015, 04:38:46 PM by LaMojo »
dilligaf
« Reply #5 on: May 09, 2015, 07:09:31 AM »
  ;-T and green is ground the world around.  :BEER:
Matt
Offline tobydmv
« Reply #6 on: May 09, 2015, 08:23:56 AM »
B+ is battery positive
D is dinamo/dynamo
At least that is what my 1955 Moto Morini Turismo uses...your D could be distributore ;D
Offline tpeever
« Reply #7 on: May 09, 2015, 09:50:41 AM »
Thanks for all the great answers guys! Sounds like I have my coil wired up for optimum spark! Startup after two years restoration is hours away!!
Batteria e distributore. Love it!
« Last Edit: May 09, 2015, 09:52:51 AM by tpeever »
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
