Author Topic: Fuel Sender Repair ?  (Read 2831 times)
Offline Karl Von
    • Classic Old Motorcycle Association
« on: May 24, 2015, 06:29:49 AM »
has anyone ever tried to repair one of  the guzzi fuel senders ?   I just picked up a quota and the fuel sender is bad.  When metered, it shows nothing.  The quota has a odd one that is very short.  I installed a spare i had for my centauro but it is a lot taller than the quota, so i imagine the gas light will come on with 100 miles left.
This sender is the later thermocoupler style.
Re: Fuel Sender Repair ?
« Reply #1 on: May 24, 2015, 07:39:44 AM »
If it's just a broken wire, you're in luck. If it is the gizmo, (technical term) I don't know any way of repairing it. Maybe you could put the Centauro gizmo on your Quota tube?
« Reply #2 on: May 24, 2015, 08:34:27 AM »
Kiwi Roy found them I believe. PM him, or a good search may find the info.
Offline ccoli
  • What? Me Worry?
« Reply #3 on: May 24, 2015, 10:07:48 AM »
I weld repaired the one in my 2003 EV. It looks like a straight metal rod with 2 flat spots that have holes at the flats for mounting screws. Mine broke at the flat spot.
If it's the type like on my SPIII, part of the petcock I doubt that it's repairable. I have my oem one I took out because it triggered at about 1/2 tank.
Wisconsin MGNOC Rep
