Author Topic: 2v big block vs 4v big block - who likes what?  (Read 16940 times)
Offline not-fishing
Re: 2v big block vs 4v big block - who likes what?
« Reply #30 on: May 30, 2015, 12:43:56 PM »
OK, 2V engine 16 bolts to remove rocker covers and four adjusters to adjust. Total of 36 *Operations* to perform to adjust valves. 8V? 8 bolts to remove rocker covers and eight adjusters to adjust. Total number of *Operations* to perform valve adjust? 24! Now, which one was quicker and easier again? ??
You've forgotten Murphy's law
With the 4v I only have 6 things to screw up valves and valve cover gaskets
With the 8v I have 10 things to screw up  and believe me Murphy seems to be my neighbor
For me thenumber of things that can be screwed up define how quick and easy it is.  this comes from decades of personal experience     :pop
« Last Edit: May 30, 2015, 12:46:03 PM by not-fishing »
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Rough Edge racing
« Reply #31 on: May 31, 2015, 07:14:46 PM »
 Suppose you were an experienced rider but never on a Guzzi...Would you be able to tell the difference between a 2 and 4 valve head after a ride?
« Reply #32 on: June 01, 2015, 07:28:44 PM »
I think so!
« Reply #33 on: June 01, 2015, 07:46:26 PM »
That's a tough one. I'd say probably not. What would you base your observations against? <shrug>
Offline Sheepdog
« Reply #34 on: June 01, 2015, 09:02:02 PM »
My Vintage is the only Guzzi I've owned, so I'm not really qualified to compare. However, I don't care for the complexity of the electronic gizmos (though I've grown rather fond of electronic FI and ignition) and I've never craved more power than the 2V delivers. I lusted for a Big Block for a long time before I finally pulled the trigger on mine back in '07. If it keeps delivering big smiles, I may never know what I'm missing...
Offline Dukedesmo
« Reply #35 on: June 02, 2015, 03:51:47 AM »
I believe it was George Orwell who said; 'four valves good, two valves better'...
Le Mans II
Ducati 916
Ducati M900
andrewdonald1
« Reply #36 on: June 02, 2015, 06:14:13 AM »
I can answer this.  Before I purchased my first Guzzi a used 02 V11, I never rode a Guzzi before.
I test rode new Guzzi's at MI before the used purchase.
Rode the 2V and 4V Griso as well as the 1st Gen Stelvio, all back to back.
I could clearly feel the difference in the 2V and 4v motors in the Griso.
The performance differences were exactly what I expected and what everyone here knows.
« Last Edit: June 02, 2015, 06:15:52 AM by andrewdonald1 »
bpreynolds
« Reply #37 on: June 03, 2015, 09:39:31 PM »
The better question in my mind is if you could not see the engines, would you think/suspect they are related?  If I was the pop of these 2 pups I'd definitely be asking mom why one of my boys was born speaking fluent swahili.
