Author Topic: 26 miles per gallon?  (Read 18082 times)
MotoGoosy
« on: May 29, 2015, 11:58:09 PM »
Seem to be getting about 26 mpg with an '02 EV11.  Kinda poor, huh?
Offline JeffOlson
Re: 26 miles per gallon?
« Reply #1 on: May 30, 2015, 12:39:20 AM »
I don't know anything about your bike, but around town my Norge drops into the 20s.
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
« Reply #2 on: May 30, 2015, 06:09:07 AM »
Yup, it's the bike's fault.
It's either incredibly badly set up or broken.
Tune it, fix it or, if you are amoral? Sell it!
« Reply #3 on: May 30, 2015, 06:09:46 AM »
Both of them have something seriously wrong with them..
« Reply #4 on: May 30, 2015, 06:56:05 AM »
The bikes too eh?  :BEER:
« Last Edit: May 30, 2015, 06:56:34 AM by Kev m »
« Reply #5 on: May 30, 2015, 07:10:47 AM »
The massive vibration is shaking all of the gas out of the tank.
The breathing in of all those gas fumes would also explain a few things.
« Reply #6 on: May 30, 2015, 07:16:19 AM »
Oh it's *That* trolling idiot.
Sorry, carry on.
56Pan
« Reply #7 on: May 30, 2015, 07:23:48 AM »
 :+1 Enjoyed all this with my morning coffee.
Offline Murray
« Reply #8 on: May 30, 2015, 07:40:37 AM »
I can achieve that on my 1100 sport, although it doesn't take very long to cover the 26 miles.
Offline Aaron D.
« Reply #9 on: May 30, 2015, 07:43:38 AM »
Connect the other spark plug.
Offline Stormtruck2
  • AKA Scotch and Cigars
  • Geese Fly in a Proper V
« Reply #10 on: May 30, 2015, 08:21:41 AM »
I was going to say the same about my Centys.  I have gotton less than a 100 miles on a tank before needing fuel.  And I know for a fact that the bike was in fine fiddle, except for that loose nut that holds on the handle bars.  ~; ::)
μολὼν λαβέ-molṑn labé
w123driver
« Reply #11 on: May 30, 2015, 09:05:40 AM »
Can's say anything if the bike has carb, but if it is fuel injected, sharp decline in MPG (given no fuel leak, no misfiring cylinder, normal tire pressure) is almost  always caused by defective oxygen lambda sensor. Stuck open O2 sensor "tells" CPU that the mixture is too lean and CPU makes injectors to deliver longer squirts of fuel. Hence the poor MPG.
« Last Edit: May 30, 2015, 09:08:07 AM by w123driver »
« Reply #12 on: May 30, 2015, 09:11:45 AM »
There is no such thing on a 2002 EV in the US.
Offline JeffOlson
« Reply #13 on: May 30, 2015, 09:18:33 AM »
There is nothing wrong with my bike. My MPG may dip into the mid-20s around town, but it reaches the mid-40s out on the highway. It really depends upon how it is ridden. I imagine the OP's mileage varies, too. He did not give us enough information...
2018 Vespa GTS 300
2015 Vespa GTS 300
MotoGoosy
« Reply #14 on: May 30, 2015, 09:21:06 AM »
Well, thanks for the few intelligent answers.  Didn't expect 40mpg putzing around town.  Just wondered if other 1100's get about the same.
Offline not-fishing
« Reply #15 on: May 30, 2015, 09:37:53 AM »
My Griso 1100 averages in the 40's, in-town on the freeway -- no real change but it may be because of my Rule #1:  Never be the first through an intersection.
You wouldn't have some Swabbie borrowing a little gas would you?
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
« Reply #16 on: May 30, 2015, 09:45:06 AM »
The lowest injected Guzzi mileage I ever got was in the Winter on the Centauro before I put a brass temp sensor on it. 33 mpg. After that, normally it got around 42. Got over 50 on a trip one time putzing along with Harley Bob on his softtail at about 60-65.
20s?? I still say there's something wrong.
w123driver
« Reply #17 on: May 30, 2015, 09:48:26 AM »
My average MPG is 44 in town/county roads on my 2007 Breva.
Offline Stormtruck2
« Reply #18 on: May 30, 2015, 09:53:54 AM »
I usually get 160 miles until I'm walking with the Centy. That works out to about 35 MPG. I would imagine I could get 40+ mpg if I was a little more mature in my riding style. :bike ;) :D  It also has a bit more of a load to haul with me on it rather than you Chuck.  :D I run nothing but alcohol free premium gas in them.
« Reply #19 on: May 30, 2015, 10:00:29 AM »
I had my Centauro under 30 MPG. I've had it over 50 MPG.
I used nothing but the cheapest swill gas I could find.
Offline atavar
« Reply #20 on: May 30, 2015, 10:06:46 AM »
I have no idea what mileage my Norge gets.  I purposefully ignore that.  Gasoline is the cheapest part of owning a bike.
I typically spend more on tires in a year than I spend on gas.  Perhaps if I lost 100 pounds and rode more maturely that would change.
Range on the other hand is more important.  I tend to get a tad over 250 miles between fills.  I guess that puts mpg about 40ish .  StarTron helps that quite a bit.
« Reply #21 on: May 30, 2015, 10:55:19 AM »
That's the bike that vibrates worse than a hard mount sportster?
Something seriously wrong here.   jus sayin'.  <hint  hint>
Offline Nick
« Reply #22 on: May 30, 2015, 11:08:39 AM »
I get anywhere from 40 to 50 on my '03 EV. It depends on my right wrist  ;)
« Reply #23 on: May 30, 2015, 11:21:29 AM »
Fuel mileage is a pretty good indicator of state of tune...
Offline dl.allen
« Reply #24 on: May 30, 2015, 11:36:15 AM »
ive owned a lot of bikes but my 04 v11 lemans is the most variable in gas mileage depending how I ride it.  From 30 to 45 mpg.  Syching the throttle bodies helped a little.
My 75 850T get great mileage no matter how I ride but then again it doesn't produce much power either.
I would just give it a tune up, fresh plugs and see what you get
MotoGoosy
« Reply #25 on: May 30, 2015, 12:48:26 PM »
Oh, it's all tuned up, but I ride around town mostly and those stoplights eat most of the gas.
Offline Dilliw
« Reply #26 on: May 30, 2015, 01:46:25 PM »
How do you check your mpg?  No reason to think the stock speedo/odo  is accurate.
George Westbury
Austin, TX
MotoGoosy
« Reply #27 on: May 30, 2015, 01:52:59 PM »
Loosely.  This week was the first time and I just took the mileage off the odo before and after fillups and divided it by 19 liters.
Offline Aaron D.
« Reply #28 on: June 01, 2015, 07:50:25 PM »
If I understand you, you are doing it wrong.
Tell me, what is 19 liters?
Never mind. I knew another person who did the same thing when calculating fuel mileage. They should have known better, too.
« Last Edit: June 01, 2015, 07:53:43 PM by Aaron D. »
« Reply #29 on: June 01, 2015, 08:15:21 PM »
My reply was only partially tongue in cheek.
My 00 Jackal was tuned somewhat rich, but despite entire tankfulls of spirited riding only rarely dipped into the HIGH 30's in the dead of winter. Generally turned in low 40's on our cheap E10 and occasionally kissed 50.
My 06 Breva 1100 was about the same, rarely dropping anywhere in the upper 30's, and, especially after a Guzzitech reflash, regularly got in the mid to high 40's.
If either ever dropped into the 20's I'd have immediately looked for fuel leaks.
« Last Edit: June 01, 2015, 08:19:30 PM by Kev m »
