Author Topic: 2002 v11 lemans---- issues?  (Read 2702 times)
Offline sarg
« on: June 03, 2015, 07:12:59 AM »
very good deal on a local one owner bike here in alberta. what were the problems? clutch? etc.
Offline twhitaker
Re: 2002 v11 lemans---- issues?
« Reply #1 on: June 03, 2015, 07:29:44 AM »
IIRC, the only issues were bubbling paint on the motor and a shifter pawl spring that breaks.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #2 on: June 03, 2015, 07:34:32 AM »
Yeah.  If it's a standard LeMans it will have a dual plate clutch.  If it's a Tenni, it came factory with a single plate clutch that could be an issue.
Bubbling paint on the cases was the biggest thing.  The shift return spring might break, if it hasn't already been replaced.  Easy fix.
Changing out the relays to Pyro Dan's relays would help the electrics.
Good bikes.
Online fotoguzzi
« Reply #3 on: June 03, 2015, 07:38:10 AM »
as said, engine paint.. carry a spare shifter spring and no worries! not ideal but can be fixed roadside.
my 2002 was fantastic and near bullet proof.
if it has been dropped check the frame to motor mounts up front (to the timing cover) case can break if hit hard.
also the tank can swell or deform, look at the area around the steering neck and make sure tank isn't rubbing the frame there.
If owner does wheelies on it the oil pump can be starved.. solution was a Roper plate, a kind of a windage tray to keep the oil in the sump. so, how was it ridden and what mileage?
oh and the driveshaft is a bitch to get to the front grease zirk.
« Last Edit: June 03, 2015, 07:40:50 AM by fotoguzzi »
« Reply #4 on: June 03, 2015, 07:39:33 AM »
Great bikes.
FTFY, Rocker.. :)
