I managed to back-probe the TPS and get a reading, but had to stop due to complete confusion.The reading when the throttle is fully closed is around 4.85V and when it's fully open it's around 120mV. Exactly opposite of what all the instructions that I can find for the V11EV say.I did see some instructions for a different model (can't find the page now) which suggested that the closed reading should be 4.85V and fully open should be 120mV.
Your readings are backwards simply because you're on the wrong terminals of the TPS. Connect to the two outside wires to get the correct readings.And 120mV @ closed throttle is too low. Set to 275 - 325 mV for the P8 ECU, or 475 - 525 mV for the 15M ECU.
The throttle linkage is disconnected.The throttle stop is fully backed out, so the butterfly is closed all the way.
In January I bought a 98 V11EV with a sidecar attached. I got a smoking deal on it
The computer is large and under the seat. So a P8 I guess.The throttle linkage is disconnected.The throttle stop is fully backed out, so the butterfly is closed all the way.I'll double check, but I'm pretty sure I'm measuring the two outer wires.
If you slide the back off the ECU connector and hook your meter up to pin 17 and chassis it's easier than trying to connect at the TPSI attached a short wire ending with a blue butt splice. The butt splice is just the right size for the meter probe.
The search function has been disabled , search through Google . TPS adjustment , Wildguzzi .com . Just a clarification for the OP David . Yeah , all good questions . Dusty
No it hasn't. The search is working fine now
